92-99 Power Window Replacement - UPDATE: Fixed!
Posted: Fri Mar 27, 2009 9:06 pm
by RegencyRoyale
Is there a How-To or Step by Step guide on how to install a new PW motor on a 92-99?
Re: 92-99 Power Window Replacement - How-To/Step By Step?
Posted: Fri Mar 27, 2009 11:56 pm
by JimmyFloyd
remove the door panel, remove the connector and the 3 bolts for the motor and pull the motor out. I believe that will do it.
Posted: Sat Mar 28, 2009 2:01 am
by RegencyRoyale
Are the motors held in with bolts or some kind of rivets that will need to be drilled?
Posted: Sat Mar 28, 2009 8:33 am
by harofreak00
Just 3 - 10mm bolts. Real simple. Pull the old motor out, put the new motor in.
Posted: Fri Apr 03, 2009 1:38 pm
by RegencyRoyale
Today I pulled the door panel and motor. Leaving the motor plugged in I tried the switch and it worked, but only in one switch direction - UP. I guess it still has to be replaced, there's nothing I can do with it?
Posted: Fri Apr 03, 2009 3:58 pm
by harofreak00
Junk it and replace it
Posted: Wed Apr 08, 2009 1:45 pm
by RegencyRoyale
UPDATE: The problem wasn't the motor. It was the master switch on the driver side. Replaced it and everything works as it should.
