92-99 Power Window Replacement - UPDATE: Fixed!
RegencyRoyale
Year and Trim: 1995 Oldsmobile Eighty Eight Royale LS
Post by RegencyRoyale »
Is there a How-To or Step by Step guide on how to install a new PW motor on a 92-99?
Last edited by RegencyRoyale on Wed Apr 08, 2009 1:49 pm, edited 2 times in total.
JimmyFloyd
Year and Trim: Past-1993 SSE
Past-1993 SSE SC
Past-1993 SSEi
Re: 92-99 Power Window Replacement - How-To/Step By Step?
Post by JimmyFloyd »
remove the door panel, remove the connector and the 3 bolts for the motor and pull the motor out. I believe that will do it.
2001 Honda Civic LX
RegencyRoyale
Are the motors held in with bolts or some kind of rivets that will need to be drilled?
Last edited by RegencyRoyale on Wed Apr 08, 2009 1:53 pm, edited 2 times in total.
Just 3 - 10mm bolts. Real simple. Pull the old motor out, put the new motor in.
RegencyRoyale
Today I pulled the door panel and motor. Leaving the motor plugged in I tried the switch and it worked, but only in one switch direction - UP. I guess it still has to be replaced, there's nothing I can do with it?
Junk it and replace it ;)
RegencyRoyale
UPDATE: The problem wasn't the motor. It was the master switch on the driver side. Replaced it and everything works as it should.
