supercharger
- Year and Trim: .
Re: supercharger
Don't forget about the exhaust and cam. If you can't flow it or exhaust it, it adds nothing. You need to know what CFM of air is being moved with whatever pulleys you are going to run.
- willwren
- Retired Admin
- Year and Trim: .
Re: supercharger
They have more than they know, and they know I know that. The market is small enough, they don't spend the time to identify every compatible part for the Series 1.Sadden wrote:well ok if you say so willwren. i emailed the intense company asking what all they sell that would fit my series one. heres what they said :
"Hi Colin,
We only have a couple items for your Series I engine – a replacement supercharger coupler and high ratio rocker arms. Both of these are in stock for immediate shipment."
thats from the original email. if you disagree and have used some of thier parrts and have written up this list i would love a list.
Back to what I said earlier:
EVERYTHING you can get for the Series 2, you can get for the Series 1 EXCEPT an intercooler. Not all parts are from our traditional Series 2 vendors, but they're out there, INTENSE sells far more compatible parts than some people ever both to identify. Dirtracr is being seriously sarcastic in his post above.
I'm currently running from INTENSE:
FWI
AFPR
MAF Translator
Rockers
Lifters
Oil Pressure Kit
False Knock Kit
Plug boot protectors (
Many gaskets, seals, and filters, supercharger parts, not to mention belts and lubricants are also available from them. If not from them, then elsewhere. What you need to do is simply state what you need and we'll send you to the right place to get it.
- Sadden
- Posts like an L36
- Year and Trim: .
1994 Bonneville SSEI
2006 Grand Prix GXP - Location: Alberta Canada
Re: supercharger
pretty much all im looking at right now (that i know of) will be pistons for the .020 overbore
and exaust to handle all that air (excellnt point myfirstbonnie)
and thats the kind of statement i like "If not from them, then elsewhere. What you need to do is simply state what you need and we'll send you to the right place to get it."
Re: supercharger
What are you using for a cam with this beast?
- willwren
- Retired Admin
- Year and Trim: .
Re: supercharger
Your stock exhaust is fine with a mild cam, and the overbore won't affect it. Upgrade your cat and muffler only.
Even your EM's don't need porting until you port the heads.
- Sadden
- Posts like an L36
- Year and Trim: .
Re: supercharger
im not sure. i like the loooks of the intense ones but idk if they fit or not.
id assume so but willwren will be able to tell for sure. if im gonna spend the money on the cam i want to get the nos version because eventualy im gonna get nos anyways so...
(and im not starting until the end of june at the earliest im just getting some help planning and figuring out what needs to be done so thank you)
- willwren
- Retired Admin
- Year and Trim: .
Re: supercharger
Intense cams will not work for you. You will most likely have to go with a custom grind, or buy one from the Holden Monaro market in Australia. Custom grind by a US shop will be far more affordable. You'll also need heavier valve springs, and we can help with that when the time comes. Again, Series 2 Valve springs, locks, and retainers will not work for you, nor will pushrods, but there are several places that can handle that for you as well. Mine were made custom for me by a shop here in Oregon (supplies them for Richard Childress Racing/Nascar).
http://www.crowcams.com.au/default.aspx
VERY IMPORTANT:
The Aussies never saw the L67 Series 1. Their series designation is different for generations from ours as well. Your Series 1 L67 cam choice is also that of the L27 which is their VN Series on this page:
http://www.crowcams.com.au/media/catalo ... n%20V6.pdf
Their ECOTEC is our SERIES 2. Their SERIES 2 is OUR SERIES 1.
VERY IMPORTANT:
- Sadden
- Posts like an L36
- Year and Trim: .
Re: supercharger
yet another part with the word "custom" attached to it. Welll then im unsure what to do with the cam. It will need a higher quality steel but any ideas on the lift?
- willwren
- Retired Admin
- Year and Trim: .
Re: supercharger
No, you won't need higher quality steel. Lift and duration are going to be dictated by what you want. Desktop Dyno is a good starting point for you, or talk to the grinder personally and discuss it with him. Or simply buy one off the shelf with the links I posted.
The problem with all these plans is this:
You drive a Series 1 because that's what your budget dictates. For what you're going to spend getting the performance where you want it, you could sell it, buy a Series 2, and go with bolt-ons. The more you mod, the more you'll spend just keeping it running, and it's very easy to pour THOUSANDS into it. The Series 1 is too old to be practically considered a good platform for aftermarket performance because of this.
Let's start with the basics now.
1. What's your budget?
2. What are your realistic tq/hp goals?
- Sadden
- Posts like an L36
- Year and Trim: .
Re: supercharger
depending on how much work i have to miss it is startiing to sound like about 4500 - 6000
and i want to see 500hp before nos but....
thats a lot to do in one summer.
- Allmachtige
- Retired Moderator
- Year and Trim: 2009 G8 GT
Re: supercharger
Series 2 with ported heads, plus everything that goes with such a setup. 500hp is still a loftly goal with stage x heads.Sadden wrote:depending on how much work i have to miss it is startiing to sound like about 4500 - 6000
Stop even thinking about doing this with a series 1.
2009 G8 GT - White Hot
FMS Custom Cam, Yank 3600 SS, 1LE (ZL1) 3.91, SLP Longtubes, Magnaflow cat-back, Rotofab CAI, tuned via HPTuners
415/391
415/391
- 95naSTA
- Year and Trim: 95 SLE
Re: supercharger
Not that hard with a S2, turbo, cam, etc.Sadden wrote:depending on how much work i have to miss it is startiing to sound like about 4500 - 6000
- Greyhare
- Posts like an LN3
- Year and Trim: 1996 VW Jetta 2.0 with Eaton m45
- Location: Adair Village, OR Survivor: WCBF '06, WCBF '07, WCBF '08
Re: supercharger
Let's start with fuel.
4 bar
0.55 BSFC (Brake specific fuel consumption) This is a little lean for a supercharged engine but not too lean.
90% injector duty cycle. This is way too high, 80-85% is the correct range.
6 injectors
500BHp
44.1lb/hr injectors required.
Now with safer numbers:
0.60 BSFC
80% IDC
54.13lb/hr injectors required at 4 bar.
62.86lb/hr at 3 bar.
Assuming a WOT A:F of 11:1
5.0288lb/min of fuel => 55.3168lb/min air
Air is ~0.0745lb/ft^3 at sea level and 70F
742.507CFM This is a lot of air and will require considerable head work. Twin M62's will need to spin at 10347rpm. With a 6000rpm red line 4.2" pulleys would be about right.
I would estimate ~$1000 for each head.
You will need custom tuning. No off the shelf PCM will handle this.
You will have a very large investment in time and/or money for the custom fabrication needed to put this together.
Can it be done? Yes.
Can it be done on your stated budget? I doubt it.
A very unique project but IMHO not practical.
4 bar
6 injectors
500BHp
0.60 BSFC
80% IDC
dirtracr95
- Posts like an L27
- Year and Trim: 1988 and 1987 Buick Lesabre T-Type
Re: supercharger
I hate the word practical. Thats all I am going to say about that.
You can use the 85mm MAF that INTENSE sells to read you air flow instead of 2 smaller MAFs for each blower. I believe the 85mm MAF can flow 895cfm or something like that. It will be easier to tune that way.
- willwren
- Retired Admin
- Year and Trim: .
Re: supercharger
Practical is a word we like to use when helping members that have stated their budget.
If you don't like the word, please paypal a bunch of money to Sadden, and we won't use it any more in this topic.
- 2000Silverbullet
- Retired Gearhead
Re: supercharger
I'm impressed with your analysis Mike. Good job.
....and yes I also agree that based on your budget, this project is not PRACTICAL !
Last edited by 2000Silverbullet on Mon May 04, 2009 4:22 pm, edited 1 time in total.
01bonneSC
Re: supercharger
Also need to think about other things on the car that might be going out or you'll need to upgrade due to the higher HP(ie brakes, no reason for the go if you cant WHOA!) maybe even suspension pieces. I think he should sell the Bonne and go with and FBody or even a FoxBody mustang, you can have a better performing car all around and go faster for cheaper, or just able to dump that many more performance pieces in the car.
I wonder how much money the 8Ball had dropped into it? That was a 460WHP car right?
- Sadden
- Posts like an L36
- Year and Trim: .
Re: supercharger
I have both the sc the custom intake will be free or next to free. (possibly supplies)
i can get a custom tune in my area for 100$. all im looking at are the pretty basic supplies and labor. now im looking at fuel delivery system, heads, and transmission work.
- Allmachtige
- Retired Moderator
Re: supercharger
I've been tuning my PCM for 8 months. Its not something you can just set and forget, especially with what you're planning.Sadden wrote: i can get a custom tune in my area for 100$.
I highly recommend you buy your own tuner and do it yourself.
415/391
415/391
Re: supercharger
No, you can't get a custom tune for $100. Your car is OBD I, and there are incredibly limited options for tuning that. If you want a car with 500 WHP, get a 98 Camaro and throw a magnacharger on it. That'll have 500 RWHP, and be a lot more practical.Sadden wrote:I have both the sc the custom intake will be free or next to free. (possibly supplies)
