Nice work!
The retrofit begins...it's done!
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: The retrofit begins...it's done!
*dang* those turned out nice. I like very much!
Nice work!
Nice work!
- LeSabreUltra
- Posts like a Northstar
- Year and Trim: 2012 Nissan Maxima SV Premium
Thanks again for the compliments guys, I'm glad I took the time to finish this up and do it right!
Sealed up my headlight today with the remainder of the 3M window weld. Should be nice and watertight.
Also got a couple more output pics:
High beams coming soon!
-Dan
_
_
__I n n o v a t i o n__T h a t __E x c i t e s
_
_
__I n n o v a t i o n__T h a t __E x c i t e s- LeSabreUltra
High beams done. Info and a how to on how you can make your low beams stay on with your highs for cheap, whether you have stock halogens or HIDs:
viewtopic.php?f=21&t=16819
I was able to retain DRLs, perimeter lighting, etc as well.
-Dan
_
_
_
_
Realized I never posted high beam output shots. This is many updates and upgrades above what was seen in the previous post.
Low beams:
High beams:
These are the low beams. I was trying to catch the color right at the cutoff line, that little flash of blue you see when an OEM HID car approaches. One of them you can see the blue, the other I'm inside the cutoff (bright one).
Output, close...
Low beam:
High beam:
Road...
Low beam:
High beam:
Crappy camera but you get the idea. I see very well at night.
Low beams:
High beams:
Output, close...
Low beam:
High beam:
Road...
Low beam:
High beam:
-Dan
_
_
_
_
ChilinMichael
- Year and Trim: 2004 Volvo S60
I thought my headlights were insane....
- wake
- Year and Trim: 96 olds cutlass supreme 4 door
honestly i bet if you where following someone they could run just parking and still see fine
Member # 534.96 olds cutlass supreme SL 4 door 3100 4t60 *3.33 gears* *Fe1* 115K bone stock DD
