transmission shifts late (arg still problem after h p fix)
Re: transmission shifts late
Not anything you would notice... you'll notice it most from a dead stop.
Night Crawler
Post by Night Crawler »
how much should the engine pull on that front mount when you shift in to gear from park? mine seemed to move almost an inch at least.
FWI, converted low beam bulbs into high beam bulbs, 20% tint all around, MSD wires, NDK TR55 plugs, auxiliary line in, scan gauge, custom FloPro/MagnaFlow Cat back exhaust
2002 Bonneville SE
Mine only moves about 1/4" with my solid front mount. 1" isn't that bad.. I have seen them move 2-3 inches before.
Night Crawler
ok i just put some transmission sea foam in it and went for a drive. I'll see what it's like in a week.
2002 Bonneville SE
Night Crawler
Well I got a person from gm to look at my car and he's leaning towards the front engine mount needs replacing since the above mentioned didn't do anything different.
What is the part number for the engine mount and why can't I find engine mounts on rockauto.com? And how much is the mount usually?
2002 Bonneville SE
Post by gonzo4191 »
do you not want a solid mount?
Night Crawler
ya but where do i get them and how much are they?
2002 Bonneville SE
trf_ssei
Year and Trim: 1998 bonneville SSEi
Post by trf_ssei »
hockey puck!
Night Crawler
seriously? just a hockey puck with a whole drilled through it?
2002 Bonneville SE
I just PM'd you this info.
jack car up, put jack stand under the engine/tranny and set jack back down... slightly.. enought to take tension off the mount... take off 3 bols on the mount, and 1 on the bottom, and remove all together
parts i picked up - pucks were $2.99 each and the bolt setup was $10
make a template to center your drill holes, however this is not really crucial
mark...
and drill...
put bolt thru
make sure everything is just as thick as the old mount
wrapped in electrical tape just for cosmetic
attach bracket in reverse order
leftovers that i can return to home depot... so about a $13 mod
I have since upgraded to the 01bonneSC style mount, just because it looks neater.
Night Crawler
ok, does the new mount bolt on on the bottom or just rest on the frame?
2002 Bonneville SE
It mounts to the subframe from underneath.
Night Crawler
one more thing, are the nuts the nylon lock nuts?
2002 Bonneville SE
They aren't in my picture, but you definately should get lock nuts. I had one come off before I updated them.
trf_ssei
Post by trf_ssei »
is there a difference between the orang and black pucks?
Some are harder, some are softer. Just depends what you want.
Night Crawler
bought the stuff and put it all in, I have a slight vibration now but I'm gonna pick up a grade 8 bolt instead of the home depot white steel bar. This way I won't have the worry of the steel breaking while under pressure.
OLD
The cause of the hard shifting
NEW
2002 Bonneville SE
That was definitely your issue!
Night Crawler
arg, well the mount is fixed but my car is still jumping when it shifts. Will adding a rubber gromet above the bottom nut help this? I know it will help with the vibration
Last edited by Night Crawler on Fri Mar 13, 2009 10:22 pm, edited 1 time in total.
2002 Bonneville SE
2003blackbonniese
Year and Trim: 2003 Black bonneville SE
Re: transmission shifts late (arg still problem after h p fix)
Post by 2003blackbonniese »
i have the same problem on my '03 SE. it currently has 111111 miles (crazy, right?) and going from first to second gear is always a struggle. it will even get up to 6k rpm, or so, and in order to get it to shift i have to take my foot off of the gas and let it shift, and then give it gas again which becomes very annoying. i definateley understand your problem!
  • 120,xxx miles,180° thermostat, cold air intake with k&n filter and heat shield, CB radio (it's necessary),
    • cleared headlights and tail lights, new tires, Sylvania Silverstar* 9005 High Performance high-beams,
    • Sony X-Plodes, Scangauge 2
