Installed 180* T-stat, problem?
velvetdreams21
Year and Trim: 1994 SSEi
Re: Installed 180* T-stat, problem?
Post by velvetdreams21 »
2000Silverbullet wrote:Cool man. Your Bonne will love you for the change. Just remember that the temp will still rise to 220 F. It will just take a little longer to get there now. :headbang:
Im glad you told me about the temp still rising cause I would have been flippin out thinkin I messed up again lol
From what I said I did does it sound like I did it correctly so far?
1994 Bonneville SSEi
Stereo: Jensen Cd Deck, two 12" 600 watt Visonik subs, 6X9 Kicker "KS SERIES" 3-Way 300 Watts (for now)
Mods: 180* T-stat, Red wire loom, and Red painted strut bar.
Interior: Blue CD Neon, Chrome racing pedals, Custom painted dash
Exterior: Tinted Taillight
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Sounds like you're okay so far. Might want to check for that seal, though. And maybe try burping the system a bit more? You'll know it's done when antifreeze is the only thing dribbling out of the bleeder on the thermostat housing.
When I drilled my 180* stat (bought the more expensive AutoZone part, looks identical to the Intense stat), the hole was covered a wee tiny bit by the rubber seal. Installed it with the hole at the 12 o'clock position, checked the antifreeze level, burped the car a lot, anally checked the level over the next few days, and haven't looked back. I like my car all nice and chilled out at 180* F. My right foot likes it too!
Boss455
Year and Trim: 1999 Buick Regal GS
Post by Boss455 »
I have a 180 stat and she still runs pretty hot, mainly due to the fact the fans don't turn on until about 208 (according to scan tool). The "quick fix" solution is to do the high speed fan bypass mod where the PCM pin is grounded through an on/off switch. Not the most sophisticated or pretty but it does work, keeps temps under 200 easy. http://www.pontiacbonnevilleclub.com/fo ... f=8&t=5042 It does set a code but does not trip the CEL.
1999 Buick Regal GS
1992 Pontiac Grand Prix 3.1 (the Backup)
2001 Chevy Venture (aka Rosie) Wife's Ride
1994 Pontiac Bonneville SSEi "Black Betty" NOW PACKIN' 2.5" OF FUN! (retired to the junkyard up above)
velvetdreams21
LeSabre in Buffalo wrote:Sounds like you're okay so far. Might want to check for that seal, though. And maybe try burping the system a bit more? You'll know it's done when antifreeze is the only thing dribbling out of the bleeder on the thermostat housing.
I havent burped it yet due to the fact I still cant find the *dang* gasket. When I can get a ride Im headin to Oreilly Auto today to get a new one and start workin on the car again. I feel like a little schoolgirl all excited about such small things I get to do lol
Boss455 wrote:I have a 180 stat and she still runs pretty hot, mainly due to the fact the fans don't turn on until about 208 (according to scan tool). The "quick fix" solution is to do the high speed fan bypass mod where the PCM pin is grounded through an on/off switch. Not the most sophisticated or pretty but it does work, keeps temps under 200 easy. http://www.pontiacbonnevilleclub.com/fo ... f=8&t=5042 It does set a code but does not trip the CEL.
I have been thinking on getting a fan switch and mounting it on my center console. I always wondered about that tho, I would forget to turn the fan off so basically it would always be on as the car was on, would that harm anything?
Boss455
Post by Boss455 »
I think your car won't get up to operating temp as quick but apparently guys here just wire in a lighted switch to show it's on so you don't forget.
1999 Buick Regal GS
LeSabre in Buffalo
The car will get up to temp just as fast as with OEM. Just that the max temp it can reach when you're moving is lower.
Is there any way to reprogram your OBDI computer to have the fans on at 180*? I know that's possible with OBDII (love those lowered fans on my car). Save you some hassle wiring up things.
velvetdreams21
Ok I have a problem. Im following the exact instructions
"Fill the radiator slowly at the cap opening with coolant. You should see and hear air bubbles disturbing the surface of the coolant in the intake manifold at the thermostat housing as they are pushed up and out of the engine."
When I took off the stat housing the coolant just kept flowing out, I put a pan underneath to catch what I could. Now it looks like the radiator is entirely empty and the housing has coolant to the brim. I start filling the radiator and instead of hearing bubbles the coolant just keeps flowing out of the housing.
Does that just mean there is no air trapped and I can continue with the install?
Ol' Timer
Year and Trim: 1991 Olds 88
Location: New Jersey - Most of Our Elected Officials Have Not Been Indicted
Post by Ol' Timer »
velvetdreams21 wrote:.
YES!
2006 Salsa Vibe - Auto - Side Curtain Air Bags - ABS - Vehicle Stability Control - Tunes No Moon - Monotone - Preferred Package - Slate Cyper Cloth - Steelie Wheels
2002 Snap Orange Beetle - Auto - Turbo
1991 Dark Garnet Red Oldsmobile 88 - Donated to Science
velvetdreams21
YES!
Yea sorry, I think I edited my last post to say that while you were typing your first response
Thanks, Ill go finish it up then
