Driver's Side Door Controls Not Working
Re: Driver's Side Door Controls Not Working
I did some calling around your area from http://car-part.com and it looks like there may be a junkyard close to you that has one. I am supposed to call him back in 1.5 hours. He said if they do have it, it will be $65 shipped to you.
Rick's Used Auto & Truck Parts USA-PA(Kersey) E-mail 1-800-366-1798
If you want to take over the transaction, thats fine by me, just call after 1.5 hours from now.
PatrickS
Year and Trim: 2003 Bonneville SLE
Post by PatrickS »
I had the exact same problem. I did not have to take the door panel off. Just gently pried up the plastic shroud around the controls and lifted out the controller. I cleaned the connections with contact cleaner and put back together. It worked perfectly. Total time 10 minutes. Total cost 0!
J Wikoff
Post by J Wikoff »
This is an old thread. If you have new information on it, please start a new thread and link back to this one.
justoyz2
Year and Trim: 2000 B-ville (stock)
Post by justoyz2 »
I need a window control module (drivers door)
