Splicing an AUX input into the CD player wiring
lilstrom13
Year and Trim: 2003 Bonneville SE
Re: Splicing an AUX input into the CD player wiring
Post by lilstrom13 »
MattStrike wrote:It will work, but over time they will loosen and not make good contact because they are not porperly retained.
If you can't find the correct terminals, just splice it into the other wire. Done correctly, with heat shrink and solder, it will last and won't look like a trained space monkey did the job. If you think you still need a connector, you could just add whatever you have to the wires you spliced, and not worry about finding the correct terminals to match the other one.
I dont know why i didn't think of that. I think i'm going to get a few of these:
http://www.delcity.net/store/T!tap-Conn ... MgodoRYAiQ
and tap into the wires i need. Will the AUX function automatically know that it's connected?
lilstrom13
So I'm going to attempt this tonight, I will take some pictures and stuff, so it might help some people.
Wish me luck.
