Uh oh
The_Maniac
Year and Trim: 2004 Chevy Monte Carlo SS (L36 3800)
Re: Uh oh
Post by The_Maniac »
I read through this entire thread. Moral of the story, pop the belt driving your water pump and you need to really evaluate how you're getting the car home.
I got my Grand Am safely home from work a couple years ago with a cracked side tank on the radiator, losing fluid pretty good on a 20 mile drive. I learned of the crack when I got to work and smelled the coolant. I used a trick I've done on some past cars, drive outside peak busy hours, get the car up to speed safely (depending on location 5-10MPH above the limit), turn the car off and cost (car is not running, not building up heat, depending on the coolant leak, may not be losing additional coolant). Once you are about 5-10MPH under the speed limit (works on cable driven speedos, on electric ones, guess), start the car up again and repeat.
During this drive, watch the temp gauge heavily as well.
Again, I've done that trick and the cars have safely survived. BUT, I don't recommend anyone else doing it unless they are 100% sure what you are doing and scope out to do it safely!
For more info about me and my cars, check out my websites below:
- 1984 Camaro Z28 5.0 Liter HO Restore Project/Big Toy
- 2004 Monte Carlo SS 3800 N/A Future daily driver
- 1994 Grand Am SE 3100 v6 Current daily with over 200,000 miles
