Best motor oil filter
Re: Best motor oil filter
Yes it is Matt. CarQuest's premium filter is also the same.
Bing
Year and Trim: S
Post by Bing »
Never paid 8$ for a Napa gold, usually the Wix is more expensive.
comatoast
Post by comatoast »
Bing wrote:Never paid 8$ for a Napa gold, usually the Wix is more expensive.
Interesting little tid bit I found on another forum...
The Wix 51040 is the filter we use on our cars, but the 51039 has proven to be a better choice
Part Number: 51036
UPC Number: 765809510364
Principal Application: GM Cars + Trucks (80-05), Mercruiser, Volvo-Penta
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Outer Diameter Bottom: Closed
Thread Size: 18X1.5 MM
By-Pass Valve Setting-PSI: None
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=12/26
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
Part Number: 51040
UPC Number: 765809510401
Principal Application: Daewoo (99-02), GM Cars/Trucks (76-10), Saab (94-98)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Beta Ratio: 2/20=15/31
Gasket Diameters
So if I read the specs correctly, the 51036 is longer, has the same basic attributes, but does better at filtration according to the beta ratios???
Current mods - FWI, Intense 1.0 PCM, 3.4"- 3.5", Intense MPS, AL 104s, 180 Stat , Intense/TG shiftkit, Aeroforce Interceptor scan gauge
Upcoming mods- 1.9 rockers, 105#springs, Headers, 103s, 3.3, tune..
51036 = S10 4x4 4.3L filter. I've been running them for the entire time I've owned 3800's.
Bing
Year and Trim: S
Post by Bing »
:btruestory: :withstupid:
swampthing
Post by swampthing »
Car takes 5 qts perfect with that filter too
Current fleet:
2002BonnevilleSE
Post by 2002BonnevilleSE »
Other then capacity using oil filter #51036,4.3L 4x4 oil filter, what other advantage is their? What brand is that number for?
Cadet Blue....Not perfect...But paid for.
K&N Air Filter and Gutted air box. 180 Thermo Cleared Corners More to come.
"Unfortunately there is one thing standing between me and that property: the rightful owners."
- Hedley Lamarr, Blazing Saddles
"One morning I shot an elephant in my pajamas. How he got in my pajamas, I don't know." Capt. Geoffrey T. Spaulding - Groucho Marx - Animal Crackers
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
2002BonnevilleSE wrote:Other then capacity using oil filter #51036,4.3L 4x4 oil filter, what other advantage is their? What brand is that number for?
Its more filtering area. PF52 is the ACDelco number, its also the old TBI 350 4x4 filter.
GoldenBullet
Year and Trim: 2001 GMC Yukon XL
Post by GoldenBullet »
Who carries Wix? I've never seen them in a parts store.
-Matt
O'Reilly's carrys Wix, along with Parts City (Franchise owned stores, same as O'Reilly's).
GoldenBullet
Ahh, I've never looked for filters at O'Reilly's.
-Matt
They're in the back, FWIW. They have the Fram's sitting out, they keep the good stuff in the back...
2000GreySSEi
Post by 2000GreySSEi »
I run supertech oil filters in my car & there a pretty decent filter for the price (around $3 out the door). I ran them in my other cars with no problems at all.
Oh here another great video on oil filter. Its long, but well worth watching.
http://www.youtube.com/watch?v=-oB_SCqp ... ata_player
2000 SSEi 4th Pontiac!! 231,xxx Current mods: Gutted AirBox w/ K&N drop in. Cleared Corners. Future mods: 3.5 pulley, 180* tstat, hi flow cat, solid motor mounts, Red-Tinted Turn Signal Tails, Projector Headlights, Turn Signal Mirrors.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Nothing wrong with a SuperTech filter for the average driver changing oil on an average schedule. They're cheap and they work.
The E-Core construction on some of them has shown it can be problematic when run longer than 6-7k miles or so, according to pictures I've seen. The filter media was more likely to have holes and be deformed. They're definitely not for extended oil change intervals.
92BonneSE
Year and Trim: 2008 Aura XE
Post by 92BonneSE »
I use ACDelco most of the time although I use the bigger filter. It's a good quality for a good price plus its made in the USA. Although if there is a oil change special going on sometime I will get a different filter so I can get the special, but never Fram!
But I am sketched by the e-core ACDelco since I heard some bad things but I've never even seen an e-core on the shelf so...
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
