"Changed Transmission Fluid, found something interesting"
Re: changed fluid
Post by Jrs3800 »
willwren wrote:Take a closer picture. That looks like a roll pin, and is very likely the early warning of impending doom. That looks very much like the roll pin that locks the pinion into the differential.
I was thinking the exact same thing.......
gold8165
Year and Trim: 2002 SSEI
Re: "Changed Transmission Fluid, found something interesting
Post by gold8165 »
here is a guide i found to change differential
http://www.grandprixforums.net/4t65e-di ... -1928.html
willwren
Post by willwren »
Big problem: No mention of checking or properly setting endplay.
viewtopic.php?f=12&t=9823
In that topic, you'll see an alternate method for removing the diff, and you can ignore the modifications to the output shaft, that was specific to my LSD install.
gold8165
Post by gold8165 »
Thanx willwren for endplay detail.Right on the money, was a roll pin from differential! Good news is its fixed now and was really no damage, due to half the rollpin was still holding everything together.Nerveless while tore down,HD diff, cover & output shaft were all changed.Once again thanx to everyone for the great info and helping save my tranny from a possibility of being damaged.
