Holy shiit! I discovered something today that blew my mind!!
After installing the new pump yesterday, I tested it with the engine off and it ran perfectly by bypassing and dumping back into the reservoir.
So today I tried it again with the solenoid valve and the frikken valve is not opening. I performed a number of tests on the valve, tore it apart, even wired it direct.....still no flow. So in desparation I removed it.
Then I went for a ride to see how much fluid would be ingested without the check valve.
Whoa!!
I couldn't believe, even with the pump off (its a diaphram design), how much and how fast the fluid reservoir emptied.....about 10 minutes until the reservoir low level light came on.....only 1/4 tank left.
I also noted that the A/F ratio was 12.5 - 13.5 at normal throttle levels during city driving. This was expected due to the methanol mixture.
BUT more importantly, the temperature stayed incredibly low at 70 F the whole time, even when I was into the throttle.
That's 40F cooler than it was before with the solenoid in place.
So when I did turn the pump on, it took off like a scalded cat and never went over 90F. Holy sheep doo-doo!!
Only problem is, it drains the reservoir in record time........but I only need 13 seconds, or less for a drag run.
