How To: Change Fuel Filter on a 2005 Bonneville GXP (No 56k)
enslow
Year and Trim: 97, 99 Lesabre
Re: How To: Change Fuel Filter on a 2005 Bonneville GXP (No
Post by enslow »
00Beast wrote:5/8 = 15.8 mm, so a 16mm wrench is just a tiny bit loose on them, I have been using 16mm wrenches on our cars w/ no issues, but I'll try a 5/8" flare wrench next time and compare. :wink:
Are the same nuts used on all GMs from '92 up? Or will a 97 LeSabre have different sizes? I'm assuming they are the same.
In another thread of mine, I've recommended this write up be placed in the tech section as it's just what I need right now, and it's well done too.
I don't know what size 92-99 has, I've never done more than an oil change on one. Just make sure you're using the correct size wrench so you don't round off the fittings.
dpnewfie
Post by dpnewfie »
Yes, the nuts are the same size.
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
palmettosunshine
Post by palmettosunshine »
You can also de-pressurize the fuel system by pulling the fuel pump fuse and trying to start the car for 5 - 10 seconds. This takes all the pressure off the fuel rail before you stick a screwdriver in the schrader valve and you won't have gas spraying everywhere.
It all works and gets the job done. :wink:
