Fog Lights?
- CMNTMXR57
Re: Fog Lights?
So, just thumbing through AutoTrader the other day, looking at Bonne GXP's, I come across a grey one... low and behold, the drivers side fog light is out.
2011 Camaro SS
- sethjamesrimrodt
- Posts like an L36
- Year and Trim: 2004 GXP
Re: Fog Lights?
Led fog lights will work. I have them in my GXP. That doesn't mean they are any good, I am now looking into hid fog lightsyourgrandma wrote:Led won't work.
Ddm hid bulbs are rubbish. The color temp is rarely matched within a pair. I've had a couple burn out in my blazer fogs. Their ballasts for that matter don't impress me either. Never had a failure of a 35w, but every 55w I've seen from them ends up with intermittant failures to ignight.
Seth
MotorheadV8
- LE Member
- Year and Trim: 2005 Bonneville GXP
Re: Fog Lights?
I'm new here. Got a 2005 GXP "Bonnie" and I've changed so many fog light bulbs I can do it in my sleep. I've taken off the splash guard underneath. Haven't tried to remove the whole headlight unit. Might try that now.
My factory manual flow chart has suggested that my fog light switch itself is shorting. Makes some sense so I ordered one from the dealer for $103. Will try GM direct for next parts. Will try this and change the bulbs - again - and let you know if this works better.
My bulbs lasted in the past about a month.
If I find that GM engineer, I'm gonna tie him to the back end of Bonnie and open her up!
RBL9014
- LE Member
- Year and Trim: 2004 Pontiac Bonneville GXP
Re: Fog Lights?
Well, just lost the passenger side fog light, so with the back covers off I got 4 1/2 months out of the bulb with only moderate usage. I guess I will have to get used to replacing these things! Small price to pay for such a great car I guess. Let's see how long the next pair lasts.RBL9014 wrote:I've had my '04 GXP for barely 2 months and I've already had a fog go out. Thanks to this thread, I was able to replace it myself. I went with 3000k 100w H3s made by Koshin and I left the back covers off to help keep them cool. I'll be sure to post when one of them goes out. Thanks for the walk thru and the tips everyone!
_____________________
Black 2004 Bonneville GXP - 47,xxx miles
- CMNTMXR57
Re: Fog Lights?
Another satisfied customer of GM's engineering on these lights I see...MotorheadV8 wrote:I'm new here. Got a 2005 GXP "Bonnie" and I've changed so many fog light bulbs I can do it in my sleep. I've taken off the splash guard underneath. Haven't tried to remove the whole headlight unit. Might try that now.
Since you did it from underneath by taking the bottom splash guard off, you did put it back on, right?
Removing the two bolts for the headlight, removing it, and reaching down is quicker and easier (especially if you leave the moisture/dust covers off the light), than trying to crawl under there and pop off those 112 stupid press-fit connectors and then working out that whole unit.
2011 Camaro SS
- sethjamesrimrodt
- Posts like an L36
Re: Fog Lights?
CMNTMXR57 wrote: Since you did it from underneath by taking the bottom splash guard off, you did put it back on, right?
Mine doesn't have one... Is it a huge deal?
Seth
- SSEiMan01
- Year and Trim: .
03 PAU - Location: DeKalb, IL
Re: Fog Lights?
Neither has Carl's car since December.
As of now, his horn sounds like it has a cold, and I worry about his FWI, though it's not a huge concern about that. Should it have one? Yeah, it was there for a reason.
James May wrote:Hello.
- CMNTMXR57
Re: Fog Lights?
Yea, you're not hurting anything, but as mentioned, it's there for a reason. Particularly with our fog lights being down in the lower portion of the bumper, in front of the wheels, splashing through puddles can definetely get water up there shorting out the circuit, blowing bulbs, etc.. But it's other purpose is to help direct airflow into the radiator, instead of out and under the car.
2011 Camaro SS
- sethjamesrimrodt
- Posts like an L36
Re: Fog Lights?
Sounds like a good enough reason to replace it
Seth
- CMNTMXR57
Re: Fog Lights?
Ahhh, stickied for all your bathroom reading pleasures... :D
2011 Camaro SS
zigger21
- Year and Trim: 1997 Bonneville SSE
2005 Bonneville GPX
Re: Fog Lights?
If you have a voltage meter it could be the switch that is defective because its very add that both lights will go out at the same time?? There are bulbs in them. I ordered HID Blue lights from Ebay and I am very pleased with how bright and blue thay are. Let us know if you have any other questions.00Beast wrote:Thanks Paul. Even the best of us forget the simple things. I'll check that tonight.
zigger21
2005 Bonneville GPX
Re: Fog Lights?
They have great prices for HID FOG lamps on Ebay that come from SK Motor sportssethjamesrimrodt wrote:Sounds like a good enough reason to replace it
Re: Fog Lights?
Yeah, we've been over this.zigger21 wrote:If you have a voltage meter it could be the switch that is defective because its very add that both lights will go out at the same time?? There are bulbs in them. I ordered HID Blue lights from Ebay and I am very pleased with how bright and blue thay are. Let us know if you have any other questions.00Beast wrote:Thanks Paul. Even the best of us forget the simple things. I'll check that tonight.
It's not the switch, it's the bulbs, and the one side's mounting point.
PaulyGXP
- SSEi Member
Re: Fog Lights?
Ordered HID fogs and lows from DDM Tuning, around $80 for both and shipping. 10 days later and they have finally arrived! Will install tonight or tomorrow and post pics!
~Pauly~
- Bvill_GXP
- GXP Member
- Year and Trim: 2005 GXP
Re: Fog Lights?
Sweet!!!! What color temp did you get? I have 6000K for my headlights and fogs!! IMO This best thing you could have ever done... You hands and pocket will thank you ( i know mine did) from the small scraps on the hand when changing the fog bulbs and the cost of buying a bulb every 2 weeks...PaulyGXP wrote:Ordered HID fogs and lows from DDM Tuning, around $80 for both and shipping. 10 days later and they have finally arrived! Will install tonight or tomorrow and post pics!
2005 Bonneville GXP Fully Loaded
- GXPete
- Posts like an LN3
Re: Fog Lights?
Where does 6000k fall in next to the oem bulbs? Are they blue or white?
2005 Bonneville GXP (SOLD), Crimson Red Tintcoat
Other Rides: 2009 Solstice GXP Coupe #606, Cool (Liquid Silver) | 2007 BMW 750Li, Toledo Blue Metallic
Past Rides: 2007 Grand Prix GXP, Red Jewel Tintcoat | 2004 Grand Prix GT2, Fusion Orange | 2002 Bonneville SSEi, Black | 1999 Regal GS, Black | 1997 Bonneville SSE, Blue-Green
1994 Cutlass Supreme S, Turquoise | 1989 Cutlass Supreme IS, Bright Red | 1988 GMC Sierra 1500, Dark Red | 1982 Regal Sport Coupe, Maroon/Silver | 1975 LeSabre, Beige
Wife's Chariot: 2006 Buick Rainier CXL, Red Jewel Tintcoat
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Re: Fog Lights?
OEM halogens are about 3100-3300K.
OEM HID setups are about 4300K.
Those who desire a slight blue-white effect should go with 5000K.
The absolute maximum I would do before you start to lose performance is 6000K, and even then you won't see as well in rain/snow/fog.
I personally will never run anything other than 4300K in the low beam spot.
- CMNTMXR57
Re: Fog Lights?
Agreed, anything over 6k and you start loosing Lumen output to get the desired blue'er kelvin rating.
stock I had 4300k Phillips D1S bulbs, I currently run 6000k Phillips D1S bulbs. I definitely dig the kelvin rating, but I will say, I do think I lost a little lumen output.
2011 Camaro SS
PaulyGXP
- SSEi Member
Re: Fog Lights?
Sweet!!!! What color temp did you get? I have 6000K for my headlights and fogs!! IMO This best thing you could have ever done... You hands and pocket will thank you ( i know mine did) from the small scraps on the hand when changing the fog bulbs and the cost of buying a bulb every 2 weeks...[/quote]
They are in!!! Waiting until dusk for pictures... 6000k for low beams, 5000k for fogs... much inproved fog brightness!
~Pauly~
- CMNTMXR57
Re: Fog Lights?
Is that directed at me? Or Repin?
As I posted above, 6k, Phillips D1S's in place of the OEM 4,300k Phillips D1S's.
2011 Camaro SS
