Tourqe converter stall
- 89bonnelmj
- SSE Member
- Year and Trim: 1989 LE
Hey guys, Im geting a used trans installed with about 88,000 miles on it and im woundering if changing the stock torque conveter out for one with a 1895 stall would have and effect worth me investing my money to. And what would be the stall of the one i curently have on my 89. thanks
157,000 miles Mods- polyurethane front endlinks,stb,180 thermostat,ceramic pads,225/60/15 Fuzion HRIs
Re: Tourqe converter stall
If you have the 2.84 Ratio you would have the 1425-1450 Stall
If you have the 2.97 Ratio you would have the 1897 Stall
The 3.33 Ratio also used the 1897 stall
Not sure how much it would really help to have an 1897 stall with a 2.84....
- 89bonnelmj
- SSE Member
Ok thanks for the info. But how should i go about finding the gear ratio on the trans im geting? I didnt see the rpo codes off the car it came out of. It came out of a 88 olds 88 was there a popular gear ratiofor those?
Can you get the VIN from it?
- 89bonnelmj
- SSE Member
I dont know i can ask the junkyard if they have that info? Would the vin be listed on the trans?
No. Ask the yard, it can't hurt.
- 89bonnelmj
- SSE Member
Yea ima ask. they should know thats important information. I think i going to go ahead and purhase the higher stall see how much of a difference it would make. Its not to expensive any way.
