HUD Failure
- Pair of SSEI
- SSEi Member
- Year and Trim: 1997 SSEI 40th
HUD Failure
HUD {Heads Up display) is blank this morning. I can hear the motor running when I change its position on windshield, so I do not think it is the fuse or location on windshield. What should be my next step?
1997 SSEI 3.8 L67 149,000 miles Moonroof, Polished Gen V w/L32 intake, 3.5 mod. Pulley, SD Headers, Intense Stage 1 tune, MagnaFlow Cat 94109, Catco catback, Autolite 103s, 180 stat, Intense FWI, 1995 OEM trans cooler, Cleared corners. KYB Excel G struts and shocks.
2006 Malibu SS 3.9 60 degree V6, Variable Valve, Tap shift Trans, 100,000 miles Bone stock
SOLD - 1992 SSEI FWI PEM Catco Cat NGK TR55 180 stat Original owner 209,000 miles Original Engine and Trans - Still strong when she left
- Sirius
- Year and Trim: 2003 SSEi
Re: HUD Failure
I'm not sure where you go from here, but if you need to replace the HUD, I have one out of my old 93 SSE I can send to you for cheap. Assuming the 93 unit is interchangeable with your 97.
Screw you, Photobucket.
- Pair of SSEI
- SSEi Member
Re: HUD Failure
Going to remove and try to solder cold joint. "Internet suggestion". But will keep your offer in mind.
Re: HUD Failure
I'm pretty sure the HUD's are different from 93 and 97. 97 being all digital and 93 being analog or cable driven?
- J Wikoff
- Year and Trim: 1992 SSE
Re: HUD Failure
I know 92 height was controlled with a cable.
- Sirius
Re: HUD Failure
Yes, the 93 is cable operated too.
