Heads up display SWITCH removal
Dankingsley22
- LE Member
- Year and Trim: 2001 Pontiac Bonneville SSEi
Title states it. I need to remove my heads up display switch because I think there’s a bad connection to the intensity text after the light was dim the other day, now off
- Benvw99
- SSE Member
- Year and Trim: 2005 Bonneville SLE
Re: Heads up display SWITCH removal
I don't have a HUD so i dont know for sure, but if I remember correctly, you will need to take off the dash bezel. This is the big piece of plastic that wraps around your gauges and extends down to the HVAC controls.
There are two push clips above the instrument cluster, so you will need to take something thin and press right in the middle until it pops off. Then gently pry around the edges until it pulls off, but be careful since there are sharp parts on the inside that can scrape the paint off the buttons on your radio/HVAC. Since you have an SSEi, you will need to unplug the DIC buttons in order to get it to come out farther. Since the HUD switch sits in the bezel itself, you will need to just reach around the back of the bezel to unplug it. Then you will need to take the bezel out of the car since it will make it much easier to unscrew the switch with more room. Then it should be out, and once you're done doing the repair, follow the instructions backwards to reassemble.
2005 Pontiac Bonneville SLE in Crimson Tintcoat.
Previous or other current Pontiac vehicles...
2003 Grand Am SE1 3.4L - Black
2008 G6 GT Coupe 3.5L - Silver
2002 Grand Prix SE 3.1L - Dark Tropic Teal
1998 Grand Prix SE 3.1L - White
Pretty sure the HUD switch just pops out with some prying. Use a plastic pry tool or a flat screwdriver wrapped in electrical tape to avoid damaging the trim.
- 2000Silverbullet
- Retired Gearhead
The switch is not the problem. The ground inside the projector for the light dimming sensor is bad......there is a post for a fix.....
Dankingsley22
- LE Member
What’s the title of the post?
- CMNTMXR57
Ok, I'll Play...
Thread title;
Thread title;
Answer #1 which is more involved and will do it the "technical" way;Heads up display SWITCH removal
Answer #2 from Ed above (00Beast), which is more of the quick/easy way;here are two push clips above the instrument cluster, so you will need to take something thin and press right in the middle until it pops off. Then gently pry around the edges until it pulls off, but be careful since there are sharp parts on the inside that can scrape the paint off the buttons on your radio/HVAC. Since you have an SSEi, you will need to unplug the DIC buttons in order to get it to come out farther. Since the HUD switch sits in the bezel itself, you will need to just reach around the back of the bezel to unplug it. Then you will need to take the bezel out of the car since it will make it much easier to unscrew the switch with more room. Then it should be out, and once you're done doing the repair, follow the instructions backwards to reassemble.
What am I missing here? GM interiors of the 90's and early 2000's were designed and made in partnership with Little Tikes and the parts *generally* snap in/out with a little prying.Pretty sure the HUD switch just pops out with some prying. Use a plastic pry tool or a flat screwdriver wrapped in electrical tape to avoid damaging the trim.
Daily Drivers:
2011 Camaro SS
Dankingsley22
- LE Member
Well I tried with a little flat blade and it was moving around but I’m not sure if there are clips around that I need to look for while I’m prying the switch gingerly and I believe I forgot to mention the image button still lights up so I think instead of a connection being bad that there are burned out bulbs
