front stuts springs make huge gap between tire and fender
mybonnelou
Year and Trim: 2005
Pontiac Bonneville SE
Post by mybonnelou »
Are there any stock front strut springs that reduce the gap in the fender well. I replaced some worn out struts with unity complete struts. The tire gap is huge, over 4 inches. Has anyone found a brand of spring that does reduce this gap. I haven't tried putting the old springs back yet but that is next.
redfury
Re: front stuts springs make huge gap between tire and fende
Post by redfury »
Not really, I looked all throughout rockauto to see if I could find compatible springs that would be shorter, but the only way is to have springs made to spec, since they don't make lowering springs anymore.
Putting the stock springs back in is recommended. It will sit back at the correct height.
