I'm new here and could use some help!
New to the forum? Introduce yourself here. Been around awhile? Tell us about yourself.
fullirishpride2
Year and Trim: 2000 bonneville se
Post by fullirishpride2 »
So I have a 2000 pontiac bonneville se. I've gone through 3 fuel pumps in 3 month's. Any idea why that might be? Also what is the best fuel filter to have on my car. When I put in the new pump next Monday "If it's here on time" I want to put a few fuel filter in since the last pump left be with little metal shavings in the tank.
Does anyone have a writeup for making a fuel pressure tester or a link to buy a cheap one?
As for the crap in the bottom of the tank do you think I should just drop the tank and hose everything out or try to suck out and wipe up everything I can reach?
One last thing- my oil pressure gauge ALWAYS reads 120 so I know that typically means it's a bad oil pressure sensor. What brand should I get and if you have a link please post it.
Thanks. My name is Steven. :helpsmilie:
J Wikoff
Year and Trim: 1992 SSE
Re: I'm new here and could use some help!
Post by J Wikoff »
What is happening when you decide the fuel pump is bad?
DCJREDLINE
Year and Trim: None
Post by DCJREDLINE »
Dont use a vacuum on your gas tank. It causes static and that could be bad for fuel fumes. Also I wouldnt use water in my gas tank either. If you must clean it they either make chemicals to do that or just wipe up as much as you can. As for the Oil sensor I just used what ever the local autoparts store had. Worked for over 5 years for me.
2004 Saturn Ion 3 Quad Coupe
fullirishpride2
J Wikoff wrote:What is happening when you decide the fuel pump is bad?
1.Car won't start. 2.No pump prime sound. 3.I always check the electrical first.
fullirishpride2
DCJREDLINE wrote:Dont use a vacuum on your gas tank. It causes static and that could be bad for fuel fumes. Also I wouldnt use water in my gas tank either. If you must clean it they either make chemicals to do that or just wipe up as much as you can. As for the Oil sensor I just used what ever the local autoparts store had. Worked for over 5 years for me.
I know about a vacuum. Lol I ment a vacuum pump to pump out the fuel my. And if I did put water in it to clean it is would drop the tank and clean it out and let it sit with a fan to dry out. And what fuel filter do you suggest?
MKMike
Year and Trim: 1993 SLE
1998 SE
2001 SSEI
2002 SSEI
Post by MKMike »
This should help for some things http://www.pontiacbonnevilleclub.com/fo ... 40156.html
Don't forget to look here http://www.pontiacbonnevilleclub.com/fo ... 25362.html
For parts I generally prefer ACDelco and Delphi.
They are not cheap but are better quality.
This is one of the cheaper, more reliable fuel pressure testers https://smile.amazon.com/ATD-5567-Injec ... ure+tester
You can often borrow one from Autozone or similar for free with a deposit.
