Air compressor thing in trunk??
Jbro238
Year and Trim: 2002 ssei
Post by Jbro238 »
my air compressor in the trunk of my 2002 ssei sounds like it works, but when i pressed the button it didnt work :p what do i do??
*** Certified Adrenaline Junkie ***
2002 white SSEI Bonneville.
INTENSE FWI
Many beginner level performance mods to come
3 10" Championship series pioneer subs in the trunk.
redzmonte
Year and Trim: 2000 SSEI
Re: Air compressor thing in trunk??
Post by redzmonte »
do you have the air hose? you need the air hose and need to have it hooked to a tire, it will inflate but without the hose the shrader valve will not open and allow air out.
Its slow but it will work.
Shane "RedZMonte"
2004 Z16 Z06: Virgin
If the compressor doesn't kick on when you push the button, you have a problem in the system. You should hear it buzzing when you press the button.
Jbro238
Post by Jbro238 »
nothing happens when i press the button but i havnt tried an air hose yet. it does sound like its compressing when i start up my car every time i can definitely hear it.
INTENSE FWI
Typanis
Year and Trim: 2001 SSEi
Post by Typanis »
Do you have the key in the ignition and in the "run" position?
jrbartholomew
Post by jrbartholomew »
ok stupid question where do they store the air hose ,,mine works with the ignition on .. do you just hook a hose to the shrader valve or is that to fill the shocks?Thanks
Jeff
2001 SSEI
2003 Corvette
2004 GSXR 1000
These cars came with an "Accessory Kit" In a black leather-look bag. Likely removed by a previous owner and lying in their garage, or a dump somewhere. Contact harofreak00 or keep an eye on eBay.
Rubidon
Post by Rubidon »
Mine does the same thing, I can let out air via the valve but when I push the button nothing happens.
GXP front break upgrade, hockey puck front mount, aeroforce gauge in right top vent, Intense FWI
