Stalling issue 1990
J Wikoff
Year and Trim: 1992 SSE
Re: Stalling issue 1990
Post by J Wikoff »
Not sure, i'd guess they are compatible, but weird things happen. On rock auto, you can click a part number and get a list if every car it fits.
Karpov
Year and Trim: 3800 1990
Post by Karpov »
Now i get that adjust... *dang*
Under the car i check that. It was totally loose but now its okay and clearance is same all the spaces.
I ordered new because old one has been swingin aroung so i dont know is it good anymore. :(
How about, can faulty icm/coil cause random missfire and rich smelling exhaust?
J Wikoff
Post by J Wikoff »
The faulty ignition stuff could. But I'd get the new crank sensor in there first before buying anything else. If it was bouncing around in there, I wouldn't trust it at all now.
Karpov
Post by Karpov »
That what i was thinkin too. Stupid stupid but ill pay for that mistake.
70euros new with post's in here Finland :D
Karpov
Post by Karpov »
Now i got new coil and icm.
I heard that icm and coil needs thermal grease. Where i but it?
There is messy picture from internet.
J Wikoff
Post by J Wikoff »
I'm not as familiar with the Magnavox set, but since it has those wires, maybe it won't need any grease? The Delphi doesn't have them, so good plate contact is more important.
Anyone know?
Karpov
Post by Karpov »
Or grease between bracket and bottom of icm?
MattStrike
Year and Trim: '99 Montana
'04 Dirtymax
'97 Camaro
'92 Trofeo
Post by MattStrike »
You can check the interchange information on Rock Auto, or the junkyard might have access to an interchange?
Boost addict
The Fleet:
'97 Camaro - Top swap
'05 STS - V8, AWD, her DD
'92 Trofeo - Fair weather DD
'99 Montana - top swap 3800
Current project:
Something cool, trust me.
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
Gone to greener pastures:
'97 LeSabre - Top swap
RIP:
'86 LeSabre - pictures
'93 SE - L67
Karpov
Post by Karpov »
Now new parts are installed. Icm, coil and new cranksensor. I drive it warm and about five times i but engine off for 5-10min and then on and drive. No stalling yet. With warm engine it misfires pretty lot in idle but runs fine on road. No misfire at cold engine. Hints?
J Wikoff
Post by J Wikoff »
Plugs, plug wires, injectors?
Karpov
Post by Karpov »
Wires new and tight. Plugs new, gap ok. Is that dantly for plug type? I have normal autolite, no platinum etc.
J Wikoff
Post by J Wikoff »
What is "dantly"?
Karpov
Post by Karpov »
Sorry, daintly what that word. Accurate or that was my meaning. No misfire code btw.
Karpov
Post by Karpov »
Checked autolites which i replaced about 300-400miles ago. No problems.
But old ac delcos back and misfire was maybe litle "softer" or smoother than autolites or i just imagine.
15miles drive and then i heared idle. It wasnt misfiring at all, maybe very very little.
So when ive been drived more then it starts to misfire more.
No matter if i shut off engine and but it on again.
Karpov
Post by Karpov »
And i pull wires off when idle. Maybe some of firewall side wire off give stablier idle than some other plugged out but nothing amazing happened. Misfire was on no matter what i plug off.
And idle is fine if you dont matter misfiring. So no rough idle etc.
J Wikoff
Post by J Wikoff »
I wonder if maybe your timing chain has gotten slack in it?
Karpov
Post by Karpov »
J Wikoff wrote:I wonder if maybe your timing chain has gotten slack in it?
No way?? 90k miles?
MattStrike
'04 Dirtymax
'97 Camaro
'92 Trofeo
Seems like a silly question - did the wires get put on in the correct order?
Boost addict
The Fleet:
Current project:
Upcoming projects:
'92 Bonneville SSE
'87 LeSabre T-type
'67 LeSabre
RIP:
'93 SE - L67
Karpov
Post by Karpov »
Yes! Idle is pretty mess if you but even one pair cross.
Now idle is been better i dont know why. Misfire is very minimal.
Karpov
Post by Karpov »
Worked fine about 600miles after new parts.
Yesterday drived 80miles. When i reversed on parking slot on my yard, it stalled. Started good after that but idle was poor.
Today starts fine and works 30miles.
What is going on? Again...
