adding heated mirrors
- human
- Year and Trim: Daily Driver: 2011 Impala LT
Weekender: '95 Aurora - Location: Pines of Carolina
Re: adding heated mirrors
Chances are the extra wires aren't there if the car didn't have the mirror upgrade from the factory. GM almost never included an inch of wiring they didn't absolutely have to.
Weekend Toy: 1995 Olds Aurora
Woosch
- Year and Trim: 95 88 Royale X2
96 Bonneville SE
06 GXP Grand Prix
You're correct. The wiring harness in my SE (non-heated power windows) is missing the positive lead for the heated mirrors.human wrote:Chances are the extra wires aren't there if the car didn't have the mirror upgrade from the factory. GM almost never included an inch of wiring they didn't absolutely have to.
'96 L36 Bonneville SE, 95k miles (leather) 17" SLE rims
'95 L36 Olds 88 (leather) (x2) (both sold)
'91 Olds 442 w-41 (1 of 204): '79 Olds Holiday 88 coupe. Factory buckets, console
1958 Impala Coupe 348 75k miles
1958 Impala convertible 283, 51k miles
so the wire its missing is the power wire from the defrost button?
Woosch
96 Bonneville SE
06 GXP Grand Prix
It appears so. I wasn't able to trace the wire on the junkyard car back to see where it goes. The unused wire in my car's power mirror wiring harness is a ground. Do the two mirror defrost power wires (one on each side) run from the mirror directly to the back of the ECC? Shouldn't there be a relay in that circuit?95se wrote:so the wire its missing is the power wire from the defrost button?
Not sure with the ecc but on my with the standard climate control its wired in a relay under the dash.
- 95naSTA
- Year and Trim: 95 SLE
Same pin as the rear defrost but through a 10A fuse.
