So, last night I decided to replace the O2 sensor, picked up a Bosch at the local O'Reillys. The old sensor
was just hammered, black deposit near the threads, and white at the tip.
Put in the new sensor, and started the car and shut it off like 4 times on my trip home from my friends, NO problems.
Went to start it this morning, and after driving it for awhile BOOM there is the Code 13 again. I did the paper clip check and sure enough it was back.
Note, I DID pull my negative cable after doing the swap to reset the computer, so I know this isn't an old code coming back.
At THIS point, with no other codes, what should I do here? Do I need to maybe clean the MAF sensor? Getting a tad frustrated.
Thanks
