Humming noise and vibration in front passenger compartment
milty
Year and Trim: 1993 SE
Post by milty »
About 2 months ago I started hearing what I describe as a load humming sound that seems to increase with MPH speed (I don't recall replaceing or modifying anything at this time) - at the same time components in the front passenger area vibrate - sun glass holder - headlight switch. The sound seems to come from the right front passenger tire area of the car. I have had both front tires balanced - they are different brands and size - 225/65/16 & 215/60/16. I thought maybe the sound/vibration was coming from the engine/transmission but if I put the car in neutral while rolling down the road the hum/vibration remains. Are the tire sizes enough to cause this issue? Should I be checking wheel bearings, CVJ joints, etc?
Thanks...Bob
Franksdad
Year and Trim: 2001 SLE
Re: Humming noise and vibration in front passenger compartme
Post by Franksdad »
check sway bar link ends when I replaced mine it made a huge difference in my ride stability noise and greatly reduced shaking
2001 SLE tints | Series III L26 | 180 T-stat |
2002 Monte carlo SS Dale Earnhardt edition (waiting on salvage title)
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Humming is typically worn tires or wheel bearings. Vibration could be anything. I don't know if mismatched diameter tires cause any of that by themselves, but I do encourage you to get matching size tires at least on the front. The difference causes the differential to be constantly be accounting for it and can cause premature failure. Maybe that's what's already happening?
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
225/65/16 and 215/60/16 on each of the front wheels? That's a huge difference and a 5% wheel speed error between the two sides. You're shredding your differential! And knowing that the diff is the weak spot on our cars, I would not drive the car more than to the tire shop. How long have you been running this mismatch?
milty
Post by milty »
About two months ago - I'll swap a back tire of the same size to the front and see what happens - I hope I have not caused any damage to the differential - I didn't know about the differential being a weak spot on these cars - I also didn't realise what I thought was a small difference in tire size is a big deal concerning wheel sensors and differential adapting - I'll also check bearings and sway bar if noise/vibration persists. I'll report back in a few days.
Thanks.....Milty
milty
Post by milty »
I swapped a same size tire to the front but still have the humming sound and vibration. I checked the sway bar it looks good and mounting hardware is in place and secure. I spun the tire and moved it in and out - to my knowledge the wheel bearing is ok. I drove the car down a long hill at about 30 MPH and put shift into neutral and shut off engine - noise and vibration remains. I'm wondering if brake shoes rotor caliper is hanging up and causing the issue - not sure what else to check. Any thoughts? Any other road test I should do?
Thanks....Milty
Bob Dillon
Post by Bob Dillon »
My vote is for the bad hub. Easy fix.
haro1225
Year and Trim: 2004 GTO
Post by haro1225 »
Sounds like a bad hub to me too, if it is the hub assembly try to get a Timken if possible.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
motopsyco
Year and Trim: 1992 SE
Post by motopsyco »
I'm with the last two guys, thinking its a bad hub/bearing assembly. Had one go bad on my avalanche did the same thing at first, but that went south real fast on that thing.
milty
Post by milty »
I'll pull wheel this weekend and take a closer look - sounds like the problem .....Milty
Bob Dillon
milty wrote:I'll pull wheel this weekend and take a closer look - sounds like the problem .....Milty
If you have to pull the hub, spray the bolts with PB Blaster and wait 30 minutes or so before trying them. You'll need a GOOD 55MM Torx. Use a breaker bar to start loosening them gradually, no impact wrenches.
