EGR question
TheMannn
Year and Trim: 2001 Pontiac Bonneville SLE
EGR question
Post by TheMannn »
I have the egr code on my 2001 SLE, it has 230,000 on it... could the converter cause this? it revs nice dont sound choked up. how can u tell if it clogged? Just wondering before i go and buy an EGR valve... Thanks.
Re: EGR question
Get under the car and tap on the cat. If it rattles it's bad.
Also if you drive it at night, it will glow if it's bad.
Re: EGR question
How about you clean or replace the EGR valve since that is what the code is for... then worry if you destroyed the cat.
TheMannn
Re: EGR question
Post by TheMannn »
Did clean the egr, no signs of build up anywhere. what brand egr valve replacement do you recommend?
Re: EGR question
Delphi or AC Delco. Get one from RockAuto, the parts stores rip you off on them.
JEzze
Year and Trim: 2000 quicksilver SSEI
Re: EGR question
Post by JEzze »
What's the code. The I'm working on egr code as we speak. I have a extra egr if ya need one. ;-)
I have replaced mine and was not the problem. After taking with the pros here I find that rearly egr is the issue.
DDM tuning HID 6000k hi/lows and fogz
FWI, 180*tstate / 18 inch enkie wraped with potenza run flats , danturs tuned pcm,
Home made motor mount / autolite 605plugs/beldin performance wires. Hogan 3 inch dp w/ magnaflow hiflo cat, zzp plot and 3.4 smoothflow MpS, trans go shift kit, 10 inch gtablet mounted running torque app.
I have a kr issue please help....
TheMannn
Re: EGR question
Post by TheMannn »
P0404 i believe ill look when i get home
TheMannn
Re: EGR question
Post by TheMannn »
Yes its code p0404 on my handheld scanner, p1404 i believe it converts to when i select GM. it just started coming on and acts like its missing at low rpm, sometimes trys to stall when i first touch the gas, i unplugged the egr connector and it runs fine. any more ideas? Hate to buy egr valve if its not it, seen too many post with people changing their egr and it still kicking out the code that why i ask. Thanks again.
