Loose park brake pedal
bradkerbick
- LE Member
- Year and Trim: 2000 SE
Hello, My park brake pedal has been loose for sometime, so I decide to have a look at it finally. The brake light comes on and the bell dings. I have just been pulling it up with my foot. So I was thinking it was just an adjustment, but that has not helped. At the caliper the park brake does come up against the stop, I even over adjusted it and it comes away from the stop. I have readjusted it and it is now just against the stop. The park brake pal is still loose, I am missing something here, does anyone have any idea what I am missing here? Thanks for your help. I did a search but had no luck finding this. Dale
Re: Loose park brake pedal
Can the cable get slack in it and need to be replaced?bradkerbick wrote:Hello, My park brake pedal has been loose for sometime, so I decide to have a look at it finally. The brake light comes on and the bell dings. I have just been pulling it up with my foot. So I was thinking it was just an adjustment, but that has not helped. At the caliper the park brake does come up against the stop, I even over adjusted it and it comes away from the stop. I have readjusted it and it is now just against the stop. The park brake pal is still loose, I am missing something here, does anyone have any idea what I am missing here? Thanks for your help. I did a search but had no luck finding this. Dale
Sounds like it is stretched........
bradkerbick
- LE Member
OK after trying this and looking at that, it seems something in the front cable is binding at the end of the travel. I can get it in place if I lock a vise grip on the adjuster and give it a smack with a hammer, I did this a few times thinking it may loosen up. No luck, will pick up a new cable next week and should be good to go.......
You can disconnect the connector from the pedal to stop that annoying dinging until you fix it.
