Noise is driving me crazy!!!
99BonnevilleSE
Year and Trim: 1996 SSEi
Post by 99BonnevilleSE »
SO only when I make a right turn in my 99SE... I hear like a metal scraping noise. It has to be a right turn with the car going at least like 10mph. Even the slightest turn as long as I'm moving at an ok speed. Any ideas? I'm stumped! :banghead:
I'm backkkkkkkkkkkkkkkkk!
Re: Noise is driving me crazy!!!
It could be a lot of things. First check your brakes and dust sheilds. Check for play in the hub and bearing and check all the steering and suspension components. When replacing the tire, make sure all the lugs are torqued properly.
Bob Dillon
Post by Bob Dillon »
I don't know, but if you solve this, post it! You might find some good ideas here.
viewtopic.php?f=19&t=17864
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Sounds like a brake pad is hanging up in the caliper, or the caliper slide pins are frozen up. When was the last time the brakes were done?
pbrktrt
Year and Trim: 1995 Buick Riviera SC
Post by pbrktrt »
I would bet on the hub and bearing.
thomjohn
Year and Trim: 1999 SE
Post by thomjohn »
It could be broken spring in starter. I had similar problem and had brakes checked and
even right side of steering replaced. found a mechanic that said up front it was in the
starter. Noise only happened when turning rt
thomjohn 1999 SE 185K
Bob Dillon
pbrktrt wrote:I would bet on the hub and bearing.
Replacing both of mine didn't help.
