My 1992 SSEi is sick :(
I am having weird idle problems, when i start the car, it will jump to 1500 rpm, then a few seconds up to 2200 ish.. then after a few minutes, it will drop to normal idle, HOWEVER, everytime i push the gas, even a little bit, it repeats this, up to 1500 then up to 2200.. Oh, and this is intermittend, 9/10 times it does this, and the occasional one time, once the car is hot, it runs fine..
I have been reading all through this forum, and have tried many things.
-Replace IAC motor
-Replace 02 sensor
-Clean MAF
-Replace Catalytic Converter
-New Spark Plugs
-New Wires
-New Air filter
-Tested TPS sensor
-Checked all vacuum lines for leaks (with carb cleaner)
-Replaced leaking valve cover gasket (front)
TO DO:
-Remove and clean TB
-Replace IAT sensor
-RE-check for vacuum leaks (incase I missed something)
Please anyone who knows a thing or two, or had similar problems, any sugestions or insight would be greatly appreciated!
