i have a bad leak where the rubber fuel line connects to the injector rail. Is there a repair kit or do I need a new fuel line and where can I get it.
Thanks
fuel leak at connector to fuel rail
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: fuel leak at connector to fuel rail
It's possible to get new Viton O-rings and put new O-rings in the quick-connect. You'll need 2 O-rings of the right size, an O-ring pick, and some patience fishing the new ones in.
- azu
- Posts like an L27
- Year and Trim: 03 SE
I had same problem and just went with another fuel rail from junkyard.
13 Chevy Malibu LS 73K
The only dumb question is the one you didn't ask.
LeSabre in Buffalo
It depends if the rail is damaged, or the quick connect is damaged. Much easier to repair a damaged quick connect than a damaged fuel rail.
