On my 04 Grand Am
Okay so today after leaving work i hit my blinker, and when it shut off the flasher kept going. None of my lights were blinking, but i could hear the flasher clicking faster than my blinkers flash.
It kept going for like 30 seconds then stoped, then went on and off in short intervals the rest of the way home. I even tried shutting the car off and turning it back on, using the blinkers, and hitting the hazards, but the flasher keeps ticking.
Does it mean the flasher is on it's way out? Anyone know how hard it'd be to replace the flasher?
Blinker Keeps Blinking
- redwingsfan34
- Posts like an L36
- Year and Trim: 01 Buick LeSabre
bonneville dan-o
- Year and Trim: 2000 ssei
2004 GXP
Re: Blinker Keeps Blinking
more than likely your flasher took a crap... very common on these i see it all the time. your hazard button Assembly should contain your flasher.
not hard at all to replace
Last edited by bonneville dan-o on Mon Aug 30, 2010 6:54 pm, edited 1 time in total.
2006 Crown Vic, white P71 interceptor. Push bar, 35% tint.
TRADED IN! 2008 G8 Ignition Orange Metallic LY7, 47k miles, Flowmasters, all options but sunroof.
SOLD! 2000 SSEI Black, 180 t-stat, autolite 104's, 3.4" MPS, custom M&D CAI, 1/8" phenolic S/C spacer, throttle body heat sheild, solid front mount, MSD wires, shift kit, 3rd brake light overlay, cleared headlights, tinted and cleared tails, 20% tint, Syntec, ARP license plate bolts Goodyear Eagle GT's,disabled DRL's, 8000k H.I.D's, pilot angel eye fogs
TRADED IN2004 GXP Black. 53,000mi.... drop in K&N filter, 5000k H.I.D. lows, 8000k H.I.D fogs, switchback 5000K turn signals. cleared headlights. 20% Tint.
- J Wikoff
- Year and Trim: 1992 SSE
It's even more likely that the factory grease in the multifunction lever assembly (turn signal and wiper stalk unit) has gobbed up and shorted the contacts. Go to http://www.gaownersclub.com and search blinker and my same screen name. There's a good write-up that someone posted or linked in the thread to fix it. I've done it on two different Grand Ams now. Worked like a charm and really easy.
EDIT:
Here ya go.
http://www.gaownersclub.com/forum/showt ... ht=blinker
EDIT:
Here ya go.
- J Wikoff
- redwingsfan34
- Posts like an L36
Ha thanks John!!
Appreciate the help.
