I have a relay which needs to be plugged back into a black two rung terminal strip located behind the glove compartment. I pulled it without noticing where it was located. Can someone provide me with a diagram to locate that relay. The terminal strip is black and has two relays plugged into it (one being the horn relay). I assume the relay plugs somewhere into that terminal strip. Would appreciate some help.
Thanks
1988 Bonneville
Relay Part # D8174
Additional numbers:
25530746
Z-7365
Need to locate Relay
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
Re: Need to locate Relay
Below are what my Chilton’s manual shows for 88-90 Bonnevilles. You’re definitely going to have the horn & fuel pump relay. 3rd one may depend on your options.
A K
B J
C H
D G
E F
Fuses
Fuses
A - Oil light relay
B - Lock relay
C - Rear defogger relay
D - A/C select relay
E - Unlock relay
F - Fog light relay
G - Not Used
H - Fuel Pump relay
J - Horn relay
K - ELC relay
A K
B J
C H
D G
E F
Fuses
Fuses
A - Oil light relay
B - Lock relay
E - Unlock relay
F - Fog light relay
G - Not Used
H - Fuel Pump relay
J - Horn relay
K - ELC relay
Last edited by Mechanical Mike on Tue Apr 20, 2010 9:17 pm, edited 2 times in total.
2006 Chevy Monte Carlo SS
Thanks for the quick response.
