Sway Bar Link change on Park Avenue 1992 - help!
J Wikoff
Year and Trim: 1992 SSE
Re: Sway Bar Link change on Park Avenue 1992 - help!
Post by J Wikoff »
I got my bolts from Lowes.
Mike Sessei
Year and Trim: 1996 Bonneville SSEi
- Stock Is A Bad Word -
Post by Mike Sessei »
I found Grade 5 & all that jazz at a local parts/machine shop.
GM specifies a 97mm length, but I'm going to grab the 100mm, cause that's as close as I can find. Everywhere else only goes to 80mm.
3.6, FWI, 1 Range Cooler, and Energy Endlinks couldn't prevent a spun bearing.
