Wheel Bearing/Hub Replacement - Front
Tools Required
J 28733-B Front Hub Spindle Remover
Removal Procedure
Raise the vehicle. Support the vehicle by the frame. Allow the control arms to hang free. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the wheel and tire assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Clean the drive axle threads of all dirt. Lubricate the threads.
Insert a drift punch or a screwdriver into the caliper and the rotor in order to prevent the rotor from turning.
Remove the drive axle nut.
Remove the brake rotor. Refer to Brake Rotor Replacement - Front in Disc Brakes.
Disconnect the ABS front wheel speed sensor harness connector. Unclip the connector from the dust shield.
Remove the wheel bearing/hub retaining bolts.
Important
Replace the hub and bearing only as an assembly.
Using J 28733-B separate the wheel bearing/hub from the drive axle.
Remove the wheel bearing/hub from the steering knuckle.
Remove the dust shield.
Clean the rust and the foreign material from the following components in order to allow proper seating of the bearing into the knuckle:
The knuckle mounting face
The bore
The chamber
Installation Procedure
Remove the protective plastic cover before installation. Do not handle the knuckle or hub assembly by the ABS sensor wire.
Install the wheel bearing/hub to the drive axle. Apply a thin layer of grease to the knuckle bore.
Install the wheel bearing/hub retaining bolts. Tighten
Tighten the wheel bearing/hub bolts to 95 N•m (70 lb ft).
Install the new drive axle nut, draw wheel bearing/hub onto the axle.
Connect the ABS front wheel speed sensor harness connector. Clip the connector to its proper location.
Install the brake rotor. Refer to Brake Rotor Replacement - Front in Disc Brakes.
Insert a drift punch or a screwdriver into the caliper and rotor in order to prevent the rotor from turning. Tighten
Tighten the drive axle nut to 160 N•m (118 lb ft).
Install the tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Lower the vehicle.
