I replaced the outer bulb but that was not the problem.
I checked the circuit from the rear connector to the bulb. There is a blue wire and a black wire. I confirmed this circuit is ok with a resistance test.
I checked for voltage on the upstream side of the rear connector (behind the trunk side trim panel). There was 12 volts for the circuit to the inner bulb, but no voltage for the circuit to the outer bulb (blue and black wires) It looks like my problem is upstream somewhere from the trunk.
I have no idea where the circuit goes from there. Is there a separate fuse for each bulb in the tail lamp? The wires for each bulb appear to go forward independently out of the trunk.
What should my next diagnosis steps be?
Thank you for your help.
Keith
