Hi, I have a '95 Olds 88 with a 3800 series II engine, OBD I 120,000 miles on it.
My problem is that the dealer and auto shops, say I have a EGR code and keep replacing the EGR.(3 times now!) I still get the check engine light on and now the car has developed a miss/hesitation .
Does anyone have any other suggestions on what the problem could be?
Thanks! Kevin
EGR Issue!
1fatcat
- Year and Trim: before cars
Re: EGR Issue!
How are the plugs and wires?
philipk65
- LE Member
- Year and Trim: 94 Olds 88 Royale 3800 series II, OBD I 120,000 K
Re: EGR Issue!
The plugs and wires are new.
- J Wikoff
- Year and Trim: 1992 SSE
Re: EGR Issue!
Can you get the specific code numbers? Many autopart stores will scan your car. Tell them it's a GM OBD 1/2 car. It'll require a special scanner/cable combo.
