Vacuum Line to Charcoal Canister
bmsgaffer86
Year and Trim: 2015 RAM 2500 CTD
Post by bmsgaffer86 »
So I was driving the other day, and my car shifted funny. But it only happened once, then upon starting and warming up the car the next day there was a bad smell. :booty:
Long story short, turns out the exhaust manifold did its thing :flame: to the plastic vacuum line heading to the charcoal canister. It severed it clear off (which explains the funny shift) then took care of sealing it right off for me (why it never happened again). So no vacuum leak.
Thats all well and good, but its too cold outside to worry about fixing it now if I don't have to :sleepy3: . So what kind of problems am I looking at if this vacuum line is left disconnected (but not leaking)? I know what the canister is and generally what it does but I am not sure about what problems it could cause. I swear up and down that the performance of the car actually improved after its 'self-modification'. :-k
Your thoughts are appreciated!
Brandon
Brandon
- 1994 White Pontiac Bonneville SE - R.I.P. 170,000 miles
- 2015 RAM 2500 CTD
spydog
Year and Trim: 1998 and 1999 bonnavelle SLE 1994 bonnavelle SSE
Re: Vacuum Line to Charcoal Canister
Post by spydog »
i wouldnt worry about it till spring my car did the same thing a month ago and i am leveing it till spring than i will replace th line
1999 SLE 98,xxx miles
1998 SLE 178,xxx miles sold for $1,400
1994 SSE 289,xxx miles
1993 SSEI 324,xxx miles sold for $500
2002 Trans Am 32,xxx miles
1998 silverado waldoch conversion 122,xxx miles SOLD
1979 Trans Am 68,xxx miles
2000 GMC crew cab long box dually 82xxx miles
azu
Year and Trim: 03 SE
Post by azu »
bmsgaffer86 wrote:So I was driving the other day, and my car shifted funny.
Brandon
My first thought is trans modulator hose. Are you sure it's the char canister? I'm sure it is, but maybe not, but if that trans hose was shot you would have bad shifts. Let us know.
13 Chevy Malibu LS 73K
The only dumb question is the one you didn't ask.
