are our cars metric ?
hi,
i went to replace my water pump, (or coolant pump as the manual refers to it), today and i thought my 97 was metric...it appears it is not. is that correct? are some systems metric and others not?
thanks,
peter
thanks,
peter
bonnevillain
- Year and Trim: 2002 SLE
Re: are our cars metric ?
Yeah, it's a Mix. Most major/core engine components are standard, where accessories will often be metric.
LeSabre in Buffalo
- Year and Trim: 2012 Eco
It's a mix. Also, some metric sizes are also found in SAE sizes.
01bonneSC
8mm is about 5/16" and 13mm is a lil bigger than 1/2"....
sorry for the rant....why! pick one and use it! i would prefer metric but i dont care which! eeerrrrrr! what a pita.
it looks like the water pump pulley bolts are standard (and very small too), and i used metric on them and now two are rounded and stuck tight....
sigh, guess i will try to grab them with a small vise grip from thr front and use a bi vise grip to turn the smaller vg. this easy job is becoming a project.
thanks,
peter
thanks,
peter
Bob Dillon
- Retired Gearhead
- Year and Trim: 1997 SE Anniversary Edition
The crazy thing is that some of the bolt heads are metric and the threads on them are SAE. Oil pan bolts have 10MM heads and are 1/4-20, for instance. That's just a tad nutty, eh?
- J Wikoff
- Year and Trim: 1992 SSE
Are you sure they aren't M6x1? It's pretty close to 1/4-20.
Bob Dillon
- Retired Gearhead
Yeah, I know, but I used a thread gauge and it came up 1/4-20. The metric was off just a tad.J Wikoff wrote:Are you sure they aren't M6x1? It's pretty close to 1/4-20.
And that kinda makes sense from a Detroit viewpoint. Why retool the drill heads? Ordering 14 bazillion special bolts is probably cheaper, and saves 2-3 cents per car.
- 2000Silverbullet
- Retired Gearhead
Funny standards but any fastener that connects with or to the engine is standard and anything else is metric. There are some studs that go into the engine, ie.exh.manifold, that are both standard on one end and metric on the other.
