are our cars metric ?
pmicaza
Year and Trim: 1997 SSEi 40th Anniv
Post by pmicaza »
hi,
i went to replace my water pump, (or coolant pump as the manual refers to it), today and i thought my 97 was metric...it appears it is not. is that correct? are some systems metric and others not?
thanks,
peter
bonnevillain
Re: are our cars metric ?
Post by bonnevillain »
Yeah, it's a Mix. Most major/core engine components are standard, where accessories will often be metric.
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
It's a mix. Also, some metric sizes are also found in SAE sizes.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
8mm is about 5/16" and 13mm is a lil bigger than 1/2"....
pmicaza
Post by pmicaza »
sorry for the rant....why! pick one and use it! i would prefer metric but i dont care which! eeerrrrrr! what a pita.
it looks like the water pump pulley bolts are standard (and very small too), and i used metric on them and now two are rounded and stuck tight....
sigh, guess i will try to grab them with a small vise grip from thr front and use a bi vise grip to turn the smaller vg. this easy job is becoming a project.
thanks,
peter
Bob Dillon
Post by Bob Dillon »
The crazy thing is that some of the bolt heads are metric and the threads on them are SAE. Oil pan bolts have 10MM heads and are 1/4-20, for instance. That's just a tad nutty, eh?
J Wikoff
Year and Trim: 1992 SSE
Post by J Wikoff »
Are you sure they aren't M6x1? It's pretty close to 1/4-20.
Bob Dillon
J Wikoff wrote:Are you sure they aren't M6x1? It's pretty close to 1/4-20.
Yeah, I know, but I used a thread gauge and it came up 1/4-20. The metric was off just a tad.
And that kinda makes sense from a Detroit viewpoint. Why retool the drill heads? Ordering 14 bazillion special bolts is probably cheaper, and saves 2-3 cents per car.
2000Silverbullet
Post by 2000Silverbullet »
Funny standards but any fastener that connects with or to the engine is standard and anything else is metric. There are some studs that go into the engine, ie.exh.manifold, that are both standard on one end and metric on the other. :roll:
