Oil soaked fuel pressure sensor
MStokes
- SSE Member
- Year and Trim: 97 Bonneville SSE.
Hey guys thanks for all the help you offer us club members. For the last 5 months I've been fighting the used engine I had installed. Last night I found the fuel pressure sensor had soaked itself with oil and seperated. Could this have been causing a lot of the problem?(rough idle, miss in #1 or #6cyl, no power above 60mph and sometimes car willnot start when warm, also vac leak? could this cause bad crank sensor code to pop up?
Sony MDX-C7900 running thru Bose system-CD changer in trunk-XM-Infinity tweeters. Autolite APP 605 plugs. New left lower control arm. New water pump, ICM, Crank sensor, MAP,TPS. Working on 2nd engine. Adding to car all the time.
- Archon
Re: Oil soaked fuel pressure sensor
Can you post a picture of what you have? I'm not aware of a fuel pressure sensor. Do you mean fuel pressure regulator? If so, do not drive the car until it is fixed. This usually wouldn't become oil soaked however. Or, is it the oil pressure sensor? Neither should throw a crank sensor code. As for the other problems, hard to say until we know what the part is.
MStokes
- SSE Member
alec_b
- GXP Member
- Year and Trim: 1996 SSEi, Bright White, Medium Teal, 197k
That's the MAP sensor, no idea why they call it the "fuel pressure sensor". Why it would be soaked in oil, I have no idea though.
Mods: Clear corners, gutted airbox, Alpine CDA-9886. Plans: 4x SensaTracs, high-flow, FM 80, 3.5 pulley, and for gods sake some good rubber.
Leaking PCV Valve?
MStokes
- SSE Member
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
pcv is under here, unplug the connector on top, twist off the top thing, and the valve sits down in there, be sure to put the o ring back on it, you'll understand when you get it out
MStokes
- SSE Member
- Extremer
- Year and Trim: BUICK PARK AVENUE 3.8i 1992
I dig this post up ... need to know where ist the PCV VALVE on 3.8i 1992 buick park ave? need photo! :sad5:
from R4 thru R6 and V6 to V8 ...
- willwren
- Retired Admin
- Extremer
- willwren
- Retired Admin
A little thanks to nunesjeff. That's his car (in my driveway a couple weekends ago for some troubleshooting).
- Extremer
then THX allso for nunesjeff!willwren wrote:A little thanks to nunesjeff. That's his car (in my driveway a couple weekends ago for some troubleshooting).
