Jrs3800 wrote:Matt's motor does feel like a Taurus 3.8 sadly...
:sad5:
ouch...... that hurts...
I did not get that amazon radiator on the cheap. I'm going to buy a 91-95 radiator with both oil coolers and buy all new lines and fittings to upgrade the transmission cooler to the larger lines.
1990 Buick LeSabre Limited 100k - Black Sapphire Metallic
Mods:
Strut Tower Brace, Type II Delco Ignition with MSD Coils, Delco 140 amp alternator, 89 Electra/PA CD Player, Audiovox CommanderMT XM Radio, V08 HD Cooling Radiator with Second Fan, 3/8" Transmission Cooling Lines, B&M Aux Transmission Cooler, F41 Front & Rear (Air) Struts, F41 Front & Rear Sway Bars, 96-00 Buick LeSabre/PA 16" wheels and tires, 89-91 SSE Console/Shifter, Class II Trailer Hitch and Wiring, $1000+ in Second Skin Sound Deadening Material, LeSabre T-Type Cluster, 91-92 Buick Century Steering Wheel Controls. Amsoil SSO 0W30 and Amsoil ATF.
Next: Cadillac FWD V8 Braces, F41 Springs, 1988-1991 Olds A/W/C/H -body Driver Info Center (already wired, waiting on a mount)
2003 Mercury Grand Marquis LSE 153k - Silver
Mods:
Pioneer AVIC X910BT Navi, 2010/2011 Mustang 18" Wheels, Class III Trailer Hitch and Wiring, Amsoil in Engine, Trans, and Differential. Damaged Jan 2012 - waiting on adjuster to determine fate -
If you are going to do that you may need the 31" Radiator Panel, the Plastic part with the Emissions info on it... You may have a 28 inch header panel...
31 inch header panel and second fan obtained from an 89 lesabre in IL yesterday, plus the wiring and the relays for that fan. will bring them back to florida sunday night.
matt
Mods:
Mods:
