hi there i have a 92 bonneville s.e. that has been running like total crap for about a good year now it idles bad and when your driving it backfires,and seems like it is starving for fuel. ive changed everything from coils to o2 sensors,pcv valve,spark plugs wires,maf sensor ect,ect,. Does this year have a egr valve and where would it be. Well i really am at my wits end. Anyone out there have a different perspective.
Thanks , Dan.I
loss of power and backfiring??
- J Wikoff
- Year and Trim: 1992 SSE
Re: loss of power and backfiring??
If the upper intake manifold is tan metal instead of black plastic, you don't have an EGR.
Have you tested the fuel pressure? At idle, at idle with the vacuum line pulled off the fuel pressure regulator, and after you turn the key off, does the pressure bleed down after a few minutes?
Have you tried a known good ignition control module?
- SSEi95
- Site Owner/Webmaster
- Year and Trim: 2002 SSEi
'01 Sierra C3 - Location: Minneapolis, MN
Have you checked the CAT to see if it's clogged / bad?
Hi there sorry for the delay in response. As for the first question. I haven't checked the fuel pressure bleed down i will check that first. And for the second. tha cat has been cut out awhile ago so that's ruled out. i'm wondering if it could be either the cam sensor or the crank sensor???. What do you think...
thanks Dan.i
thanks Dan.i
O.k. i took another stab at this problem today with another angle. I went to princess auto and bought a set of spark plug wire testers and started checking out each wire. i came across one wire that would lite up when started and then when it would die out after a bit. it ended up being the 2-4 coil. it runs awesome now. Thanks guys for the help.
Dan.I
Dan.I
- bill buttermore
- Retired Gearhead
Thanks Dan, for letting us know what you did to fix it. It may help out the next fellow with the same problem.
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
