Since everyone else is buying cars (SOLD - page 9)
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
Re: Since everyone else is buying cars...(more pics on page 2&3)
You and you're magical prices, lol.
Sweet progress! I guess the car doesn't fit in the garage straight?
- harofreak00
I want to be able to close the garage door without moving the lift. Sideways was the only way.
- GoldenBullet
looking good andrew.
so the headliner just comes out and you put the new fabric on and put it back in? im planning a full interior teardown over my winter break.
-Matt
- harofreak00
Check my headliner post, step by step
tripscarcare95
- Posts like a Northstar
- Year and Trim: 1995 SSei
1987 GN 16K Original
Looks like alot of work, the interior cleaned up really nice,
looks good
looks good
- dissmn8
- Year and Trim: 2001 Bronzemist Metallic SLE
WOW!! Nice work!
Your hired!
114K and going
114K and going
- harofreak00
This is my practice tranny.
Not much wear on the fourth clutch shaft assembly
but the chains are shot... there is supposed to be at least 3.2mm of clearance here:
and there is literally ZERO clutch material left on the 4th gear clutches:
- radomirthegreat
- Year and Trim: 1994 SSEi 1999 SLE
That looks insane. Do you have clutches with some material whose pictures you could post? I'd appreciate it.
94 SSEi - Project car
99 SLE - Tuned with different parts and such
85 Porsche 944 - Daily driver
68 Chevy C-10 - Free truck! Needs parts.
- harofreak00
Maybe someone else has a better picture, but here is what new ones look like.
BTW, here is what a failed 4th clutch shaft looks like: This is what I am hoping and expecting to be wrong with the Bonneville's trans.
- Hans
- Year and Trim: '07 MDX | '13 TL | '06 GTO
practice trans?
- harofreak00
check the last post on page 3
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
Those 4th steels from the 97 GS practice trans are pretty burnt. I'm betting the guy liked to punch it on the freeway, going in and out of OD a lot.
And those chains are BAAAAAD...total leadfoot
Did they leave marks in the case? If the 2000 SE's chains are as bad as that, I've got a used set that, while slightly stretched, are WAY better than those.
The apply plate (part 528) doesn't look too bad, save it. Also, grab that reluctor wheel off the drive sprocket if the pins are tight, in case the 2000 SE's reluctor wheel pins are not. If all your reluctor wheels are FUBAR, I have a good one.
Save the plastic thrust washers off the drive and driven sprockets, in case they are better than the ones on the 2000 trans.
You can see wear on the 4th clutch hub, but it's not too bad, actually.
How do the splines on the pumpshaft look? If pumpshaft OK, save that too so you can use whichever's better.
According to the parts catalog, the OEM 4th clutch friction thickness is 0.070" new; got calipers?
Bone Stock
Retired
Bone Stock
Retired
- TenGHz
- Year and Trim: 2005 GXP
I wish you lived closer, I'd have a blast helping you with that. Even if helping meant standing there watching. I'd love to learn more about trannies and stuff.
-Joshua-
- harofreak00
No marks in the case, but ya, its still BAAAAAD!agrazela wrote:And those chains are BAAAAAD...total leadfootDid they leave marks in the case?
The pins are tight, I'll keep it.agrazela wrote:Also, grab that reluctor wheel off the drive sprocket if the pins are tight, in case the 2000 SE's reluctor wheel pins are not.
It looks OK, I'll save it also.agrazela wrote:How do the splines on the pumpshaft look? If pumpshaft OK, save that too so you can use whichever's better.
You are talking about #501 on page 28, right? Looks like 0.0685-0.0690". Is that supposed to wear?agrazela wrote:According to the parts catalog, the OEM 4th clutch friction thickness is 0.070" new; got calipers?
Its only 3 hours man, and I'm guessing you would be better than my girlfriend at snatching tools (although I must admit, shes *dang* good!)TenGHz wrote:I wish you lived closer, I'd have a blast helping you with that. Even if helping meant standing there watching. I'd love to learn more about trannies and stuff.
Here is where I got tonight. Then sun is going down, and will be set in about an hour, so I figured it was a good quitting time.
The biggest issues I ran into were the brake lines. I ended up being able to just bend (VERY slightly, not even close to damage) most of them so I didn't have to disconnect anything.
And here everything is supported by old railroad ties, so I won't need to worry about anything collapsing (even though I have the jackstands under there also.
Tomorrow I'll have the side cover off, dig into the trans as far as I did with the practice one, and then as long as things look good inside, I'll start putting it back together.
- TenGHz
Very cool progress shots.
Call in sick for me and I'll be there.
Some of us have jobs!
-Joshua-
- 2000Silverbullet
- Retired Gearhead
Re: Since everyone else is buying cars (more pics on page 2,3&4)
Excellent pictures Haro!
Watch those brake lines.
So is that as far as you are going to drop it?
Why not pull the whole thing out and clean it up good.
- harofreak00
Brake lines were the most watched thing during the lift, they are fine now that nothing is moving anymore.
Thats all the further I need to drop the subframe to get the side cover off.
Its SOOO much more work to pull the whole engine/trans, and there is so much more stuff to disconnect. I did all that you see pictured in about 2 hours.
- 2000Silverbullet
- Retired Gearhead
So could one rebuild the entire transaxle in that position?
- harofreak00
No, not recommended. I am not removing anything more than what you see on my "practice trans". I am not removing the Reverse and Forward Servos, Pan and Filter, Accumulator Assembly, VSS, Differential, and Output shaft. That's why this option was taken
- dissmn8
So you are full on betting this is the only issue with the Trans? Are you able to replace the clutches in this position?BTW, here is what a failed 4th clutch shaft looks like: This is what I am hoping and expecting to be wrong with the Bonneville's trans.
114K and going
114K and going
