It is currently Wed Jan 23, 2019 8:30 am
Post new topic Reply to topic  [ 6 posts ]
 Post subject: nozzle next to trunk
PostPosted: Thu Jan 19, 2012 8:11 am
Year and Trim: 03 Pontiac Bonneville SSEi 125,xxx miles
i see that there is a air nozzle next to the trunk lock and a button. do i need to put air in it?
 Post subject: Re: nozzle next to trunk
PostPosted: Thu Jan 19, 2012 8:18 am
You would normally get air OUT of that...It's an inflator. There is a hose that attaches to it that comes in your accessory kit that you can use to inflate a tire if you have about 20 years to wait, or a beach ball or stuff like that. It runs off of the compressor for the ELC for the rear suspension.
I assume you're talking about the button and schrader valve by the latch? The accessory kit I speak of is in the left corner of the trunk in this pic. :btruestory:
EDIT: A thread I started a while back asking when people have used this, for your reference.
viewtopic.php?f=8&t=23751&p=244384#p244384
92 Bonneville SSE | L67/4T60E | 72K mi | Med Slate Grey w/ Two-Tone Grey Int. | Low Miles Time Capsule
92 Lumina Z34 | LQ1/4T60E | 177k mi | Torch Red w/Grey Int. | Summer Daily Driver and Future Turbo Racekar
03 Park Avenue Ultra | L67/4T65E-HD | 188K | White Diamond Metallic w/Shale & Cashmere Int. | Rust Free Southern Sourced Daily Driver
99 Tahoe LT | L31/4L65E | 237k mi | Spiral Grey Metallic w/Grey Int. | Daily Winter Rig and Portable Concert Hall
04 Cadillac SLS | LD8/4T80E | 186k mi | Red Jewel Tintcoat w/Shale & Grey Int.
09 Malibu LT | LE5/4T45E | 205K mi | Seafoam w/Blk Int.
13 Explorer XLT | 3.5/6F55 | 141k mi | Kodiak Brown w/Blk Int.
James May wrote:
Hello.
PostPosted: Thu Jan 19, 2012 9:16 am
Some models of Bonneville have had this since 1992. I assume you don't have an owner's manual? You should make it a priority to get one.
PostPosted: Thu Jan 19, 2012 1:54 pm
Your car came from the factory with said Accessory kit, which included, among other things, an air hose and fittings that screws onto that port, and when the ignition is on and you push the "AIR" button on the other side of the latch the pump will run and provide compressed air to that port. You can get air out for tires, beach balls, air mattresses, etc.
It's pretty obvious that your car didn't have that kit (Most have disappeared by now). The compressor for that is also used as part of the Electronic Load Control system to keep your car at a normal ride height when you have passengers and cargo.
PostPosted: Thu Jan 19, 2012 8:18 pm
is there anywhere you can get this kit?
PostPosted: Thu Jan 19, 2012 8:46 pm
If your local dealer can get the part number for it, you can order it from GM Parts Direct, or one of the other GM parts wholesale sites.
There are no new unread posts for this topic. 1996 Bonneville - Fire started in trunk by trunk release
hunt2cbr
Sat Oct 17, 2015 1:23 am
ddalder View the latest post
There are no new unread posts for this topic. trunk net
unclebubbaSE
Tue Nov 03, 2015 4:21 am
unclebubbaSE View the latest post
There are no new unread posts for this topic. Water in trunk...
chopper442
Fri Jul 04, 2008 12:23 pm
bonnevillain View the latest post
There are no new unread posts for this topic. What Junk is in Your Trunk?
4793
Fri Jan 16, 2009 12:35 pm
freneticburn View the latest post
There are no new unread posts for this topic. Trunk air compressor
MStokes
Mon Mar 23, 2009 7:22 pm
Night Crawler View the latest post
Users browsing this forum: No registered users and 8 guests
