It is currently Sun Jun 24, 2018 6:26 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Tue Jun 10, 2008 3:24 am
Year and Trim: 1994 SSEi
Since I have an aftermarket cd player the buttons on my steering wheel dont work and therefor am finding it to be rather ugly and useless (if the buttons worked it would be neither). I want to replace it whenever possible and was wondering, since its got an airbag, how hard would it be to add a non airbag steering wheel to it? I ask cause I prefer one of the racing wheels or just something different such as:
If I remember correctly (btw is that what IIRC stands for?), each of those are universal steering wheels
1994 Bonneville SSEi
Stereo: Jensen Cd Deck, two 12" 600 watt Visonik subs, 6X9 Kicker "KS SERIES" 3-Way 300 Watts (for now)
Mods: 180* T-stat, Red wire loom, and Red painted strut bar.
Interior: Blue CD Neon, Chrome racing pedals, Custom painted dash
Exterior: Tinted Taillight
PostPosted: Tue Jun 10, 2008 6:59 am
Year and Trim: 1990 Bonneville LE
You can, there's nothing special about the steering shaft GM uses. As far as the airbag goes, obviously you will need to remove it. I don't know if you have to put any jumpers/changes in on the wiring harness after it is remove to keep the system from flagging an error code. You can just disconnect it from the module and see what happens first.
PostPosted: Tue Jun 10, 2008 8:40 am
I think you have to disconnect the battery for a set period of time, to allow the airbag and sensors to discharge completely, otherwise it will go off on you
PostPosted: Tue Jun 10, 2008 10:06 am
Considering you JUST got your license, this would be the stupidest mod you could do. Removing a key safety device? If you take out the drivers side, the passenger airbag is automatically disabled. If you are going to be stupid, don't take your passengers with you. Don't do it.
This is the mod you need: http://www.crutchfield.com/S-Rd4zzXklIR ... ?i=127SWIX
-Andrew-
2004 Bonneville GXP | White Gold Tricoat | custom built supercharged 3800 hot rod
2005 Town & Country Limited | Butane Blue Metallic | 270k | Family Hauler
2002 Ram 1500 Quad Cab Sport | Black| 190k | Official Bonneville Hauler
PostPosted: Tue Jun 10, 2008 10:11 am
Year and Trim: 2000 SE
Don't do it.
Just get this to make your aftermarket stereo to work with your buttons...
http://www.crutchfield.com/S-wBOA5J2EII ... ?i=127SWIX
Edit - haro beat me to the link. ^^^
Current: '12 Audi S4 Quattro Prestige 6MT
Previous: '06 Audi S4 Quattro 6MT (for sale!)
'06 Chevy Cobalt SS, Stage II: 2.0L Supercharged, 16psi boost, G85 Package; Recaro Racing Seats, Limited Slip Differential, 5 Speed Manual
'00 Pontiac Bonneville SE ( 4 years, 197,000 miles)
'99 Dodge Intrepid ES (1 year, 2 engines)
'95 Chevy Lumina (2 years, 164,000 miles)
PostPosted: Tue Jun 10, 2008 2:15 pm
Uh I just want to quickly point out that I may have just gotten my license but Ive been driving for years. Because Ive been driving illegally for so many years I quickly learned how to drive without the cops looking your way at every moment, my friends actually say Im the safest driver.
That being said: Thanks, someone told me once you get a new cd player the buttons will never work again so I figured it would be done. At some point I will want a new steering wheel tho (now that I know the buttons can still work itll be pushed much farther down the list), anyway to do that without disabling the passenger side airbag?
PostPosted: Tue Jun 10, 2008 2:22 pm
Wow, are you actually bragging about something as foolish as that?
-Andrew-
PostPosted: Tue Jun 10, 2008 2:26 pm
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
2013 Audi A4 6MT
Oh ok, then I guess that makes it perfectly fine, right? :roll:
That's not the point. If you disable one airbag, you disable the other. If you're taking a bunch of friends home in the middle of the night and a DD hits you, then what? You'll have that burden on your shoulders for the rest of your life, if you survive... Come on, all that for a riced-out steering wheel? There are much better mods you can do...
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
PostPosted: Tue Jun 10, 2008 2:35 pm
Im not bragging at all, what Im saying with that is that when you drive illegally you learn real quick how to drive really safe
PostPosted: Tue Jun 10, 2008 2:36 pm
I dont want to disable to passenger airbag, thats why I asked how to do it without disabling the passenger airbag
PostPosted: Tue Jun 10, 2008 2:46 pm
Year and Trim: '92 Roadmaster
BTW just to make this clear... if you DO remove the airbag, and you get into a accident, your insurance will NOT cover anything, because you removed a safety device from your car that it came with. My friend got into a accident in his '92 Cougar, and he had a aftermarket Grant steering wheel in there, and his insurance wouldn't cover anything because he deleted a safety device that the car came with.
I've even heard of cars being taken off the road because the factory airbag wheel was removed for a aftermarket wheel.
It may just be Ohio... but check with your state's laws.
2009 Escape Limited - 4WD - V6 - 108k
1992 Roadmaster - L05 V8 - 110k - Minty
PostPosted: Tue Jun 10, 2008 2:48 pm
I never thought of that, I will have to check it out. Thanks for the heads up
PostPosted: Tue Jun 10, 2008 2:49 pm
And the insurance companies have every right to do so. When you insured the car, the rate was based, in part, on the equipment in the car..they gave you a discount for the airbags. If you delete them and don't correct the policy, then they have every right to deny the claim.
PostPosted: Tue Jun 10, 2008 2:54 pm
Yea, I may stop by my insurance company later just to find out.
PostPosted: Tue Jun 10, 2008 4:56 pm
So you drove for several years without a license.... I guess this means you were uninsured as well? I would have to say that is far from being smart... I could have just imagined what would have happened if you had gotten into an accident, even if it wasn't your fault you would have been in some serious trouble..
Removal of the air bag... Like stated if you were to wreck your car the insurance can kill off your claim if you have an accident... Lets look at this another way... You try like you might to avoid an accident.... You end up hitting the other car head on.. No Air bag so you get to Kiss that nice new steering wheel and it snaps your face in several places.... Then being that you removed the air bag the insurance company drops your claim, You'll be into the medical bills for some extreme $$$$$$...
If you did get into an accident and you had a friend with you, would you want your friends planted into the dash? Or would you want that passenger protected?
I just don't see the reason to remove a safety feature such as an air bag..
You can do what you will and want to do like driving without a license, without insurance, no air bags... But they all come at a price..
Good Day
PostPosted: Tue Jun 10, 2008 5:23 pm
Remember that it isn't always YOU that is the unsafe driver that causes an accident. Even the single most safe driver in the world is still at risk of an accident because of other drivers :wink:
Check out my detailing page on facebook! --> Next Level Detailing
PostPosted: Tue Jun 10, 2008 5:38 pm
Year and Trim: 1997 SSEi
Not sure about your state, but in the state of New Jersey (and probably many other left-leaning states) your car will fail state inspection if you remove any factory airbags. If your car came with airbags from the factory, your car must have them in place to pass inspection.
A buddy of mine has a aftermarket steering wheel in his 3K GT and when he goes for inspection he places the stock steering wheel back in it's place so he can pass. Of course legality of this is also under question.
Even if it's not illegal to tear out factory airbags in your state, I'd highly recommend sticking with the stock steering wheel. I think those aftermarket ones look like crap anyway. Plus I think aftermarket steering wheels just scream ricer. :brice:
1997 SSEi | Bright White | 170,000+ Miles | Stock | Best 1/4: 15.374
PostPosted: Tue Jun 10, 2008 8:19 pm
Ok, does nobody see that I keep asking if its possible to take out mine without disabling theirs? Because it keeps getting brought up that theirs will be disabled.
PostPosted: Tue Jun 10, 2008 8:21 pm
Well i plan on going to my insurance company and talking to them about it first. Idk I guess to each their own cause I really like em
PostPosted: Tue Jun 10, 2008 8:43 pm
Year and Trim: 2007 Grand Prix GT
Can you disable the driver side air bag and not the passenger side one? yes you can. If someone on here tells you how to do it and you get in a wreck and die, then the person who told you how to disable a safety device is in deep *shoot*. Good luck finding help on this topic.
If you have any other questions about FIXING your car or mods that wont cause personal injury then we are here to help.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
There are no new unread posts for this topic. How NOT to change a steering wheel
labonnevillastrangiato
11
1323
Tue Aug 05, 2008 5:18 pm
Skippy1827 View the latest post
There are no new unread posts for this topic. Steering wheel play
pdiddy123
12
1359
Fri Jun 24, 2016 5:48 pm
96 SSEi View the latest post
There are no new unread posts for this topic. How do you disable a whole steering wheel assembly 00-05 ?
SPLLOUDER
Tue Nov 06, 2012 9:35 pm
SPLLOUDER View the latest post
There are no new unread posts for this topic. adding steering wheel radio buttons.
Troyport
Fri Jul 25, 2008 8:17 am
Troyport View the latest post
There are no new unread posts for this topic. Tan Interior/Black Steering wheel (95se)
crzydmnd72
Sat Jun 06, 2009 9:24 pm
Whitecrystal1 View the latest post
Users browsing this forum: No registered users and 3 guests
