1993 SE with SLE appearance package. Factory stock except for steering wheel buttons, AM/FM/CD from a '93SSEi and chrome wheels.
1999 Olds Eighty-Eight LS Anniversary Edition, my daily driver.
2004 Chrysler Minivan, wife's daily driver.
Ha, I edited the links too.. I don't do this all that much. Now a viewable picture. Thanks, though. Mike
Wow, that looks amazing. Did you have the wheels re-chromed? Otherwise that chrome is flawless!!!
Bye Bye: RIP sandrock
The wheels came one at a time, slow process, through a local wheel guy and ebay. 2 of them were very gently used, not a mark on them, no staining and no pitting - you could see a slight discoloration where a wheel weight once was, which polished out. One wheel was NOS, never mounted. The last wheel had been rechromed - and is actually the nicest one, the chrome is smooth and perfect even deep in the lugnut holes. No wheel weights on the pretty side, I had the tire guy use the stick-on weights. We'll see if they stay! I still have the gold lace wheels, ha, you can see one of them near my Olds in the background. Mike
Ok, makes sense. Just know that with stick-on weights, they will never be perfect, as you can't get it perfect without the weight on the edge of the wheel, as of yet. Just know that if there is a tiny vibration, that's more than likely what it is, and it's probably about as good as it's going to get.
Dude looks amazing!
How much on the Paint job if I can ask?
f1.4 and be there ----> http://www.fallbrookstudios.com 95 Black Bonneville SLE Supercharged / 95 Green SE, Daily Driver / 95 Black BMW 740iL / 06 Jeep Wrangler 3 inch lift 33in Tires / 2005 Tricoat GXP 32k / 2004 GXP *in car heaven*.
Cost on paint job is hard to say - I'm the painter! I bought a gallon of base, I've purchased 2 quarts of primer. I used up a half-gallon of clear I had in stock and then bought another one. Not counting sand paper, rubbing compound and my time - about 500 bucks in paint material.
It wasn't a mask, scuff and go paint job. The body shell I used was green - so it has been painted black 100%. If you remove the exhaust heat shields, you'll find black. Take out the dash and the dash wiring harness, headliner - everything, and you'll only see black. Mike
-driverjohn2005 "Gravenge" -1992 Pontiac Bonneville SSEi- Sold 4/29/12 to "myfirstbonnie" Current Rides:2015 Mitsubishi Outlander Sport GT AWD & 1999 Ford F-150 Lariat 4x4 SuperCab
Wow, lots of questions. Thanks, and thanks for the compliments!! I hope I answer them all..
1) No rotisary (spelling?) I had the body shell on blocks, quite high up, painted it on my back.
2) When I am done, it will be a sunny day summer car. Although my 15 year old daughter has her eye on it, which is pretty funny.
3) I expect to have it done by spring. All the parts that are not on it need to be painted, and I have some house projects to do now. My younger daughter is on a swim team, my older daughter dances ballet, jazz, and pointe - so I am busy with much more important things.
4) I will take a picture of the interior at some point to show off the front door speakers from thing 2.
When it is finished, I have several hours of tweaking to do on it. Little things like very small areas that need a little more buffing, etc. This is what I plan to do over the winter.
Mike
