1992-1993 Vin 1 PCM Trouble Code Definitions
Moderator: Gearheads
Post by Jrs3800 »
12 - Diagnostic Codes
13 - Oxygen Sensor Circuit ( Open Circuit )
14 - Coolant Temperature Sensor Circuit ( High Temperature Indicated )
15 - Coolant Temperature Sensor Circuit ( Low Temperature Indicated )
16 - System Voltage High/Low
17 - Spark Reference Circuit
18 - Cam/Crank Error
21 - Throttle Position Sensor Circuit ( Signal Voltage High )
22 - Throttle Position Sensor Circuit ( Signal Voltage Low )
23 - Intake Air Temperature Sensor Circuit ( Low Temperature Indicated )
24 - Vehicle Speed Sensor Circuit
25 - Intake Air Temperature Sensor Circuit ( High Temperature Indicated )
26 - Quad-Driver " A " Fault
31 - PRNDL Switch Circuit
34 - Mass Air Flow Sensor Circuit ( Grams Per Secone Low )
36 - Transaxle Shift Control Problem
38 - TCC Brake Input Circuit
39 - Torque Converter Clutch Problem
41 - Cam Sensor Circuit
42 - Electronic Spark Timing Circuit
43 - Electronic Spark Control Circuit
44 - Oxygen Sensor Circuit ( Lean Exahust Indicated )
45 - Oxygen Sensor Circuit ( Rich Exahust Indicated )
51 - MEM-CAL Error ( Faulty or Incorrect MEM-CAL )
54 - Exahust Gas Recirculation Fault ( EGR Solenoid # 2 )
55 - Exahust Gas Recirculation Fault ( EGR Solenoid # 3 )
56 - Quad-Driver " B " Fault
57 - Boost Control Problem
58 - Personal Automotive Security System ( PASS-Key ) Fuel Enable Circuit
61 - Cruise Vent Solenoid Circuit
62 - Cruise Vac Solenoid Circuit
63 - Cruise System Problem ( SPS Indicated Low )
65 - Cruise Servo Position Sensor Circuit
66 - Low A/C Refrigerant Charge
67 - Cruise Switches Circuit
68 - Cruise System Problem ( SPS Indicated High )
69 - A/C Head Pressure Switch Circuit
For 1992 Models if you have a code 58 and your car starts every time, disregard the code as it was a problem in the 92 PCM.
