1992 Vin L PCM Trouble Code Definitions
Moderator: Gearheads
Post by Jrs3800 »
codes for the 1992 Vin # L bonneville SE,SSE
12 - Diagnostic Mode
13 - Oxygen Sensor ( Open Circuit )
14 - Coolant Temperature Sensor Circuit ( High Temperature Indicated )
15 - Coolant Temperature Circuit ( Low Temperature Indicated )
16 - System Voltage High/Low
17 - Spark Reference Circuit
21 - Throttle Position Sensor Circuit ( Signal Voltage High )
22 - Throttle Position Sensor Circuit ( Signal Voltage Low )
23 - Intake Air Temperature Sensor Circuit ( Low Temperature Indicated )
24 - Vehicle Speed Sensor Circuit
25 - Intake Air Temperature Sensor Circuit ( High Temperature Indicated )
26 - Quad-Driver Fault
31 - PRNDL Switch Circuit
34 - Mass Air Flow Sensor Circuit ( Grams Per Second Low )
36 - Transaxle Shift Control Problem
38 - TCC Brake Input Circuit
41 - Cam Sensor Circuit
42 - Electronic Spark Timming Circuit
43 - Electronic Spark Control Circuit
44 - Oxygen Sensor Circuit ( Lean Exahust Indicated )
45 - Oxygen Sensor Circuit ( Rich Exahust Indicated )
51 - MEM-CAL Error ( Faulty or Incorrect MEM-CAL )
58 - Personal Automotive Security System ( PASS Key ) Fuel Enable Circuit
61 - Cruise Vent Solenoid Circuit
62 - Cruise Vac Solenoid Circuit
65 - Cruise Servo Position Sensor Circuit
66 - Low A/C Refrigerant Charge
67 - Cruise Switches Circuit
68 - Cruise System Problem
69 - A/C Head Pressure Switch Circuit Problem
