It is currently Sat Feb 16, 2019 5:05 am
Post new topic Reply to topic  [ 5 posts ]
PostPosted: Wed May 21, 2008 5:10 pm
Is this not a feature of the new site :?:
2000 SSEi - SilverBullet - 73,000 kms, 4" "straight shot" custom headlight ram air inlet, TOGs, 1.9's, Lsd, 2.9-3.4"MPS 10-15 psi, Ported GenV, EGR eliminated, OR pushrods, oil volume kit, trani cooler & shift kit, Titanium retainers, 90 lb springs, 160 Stat, 42# injectors, Fuel pump voltage increase, Wideband O2, 3" to dual 2 1/2" Magnaflows, Snow Meth/water injection, after SC temp gauge, 255/50WR17, timing commander set 15-18*@WOT, 2 speed Fan over-ride, disabled DRL, Solid motor mount, Meziere Electric water pump, adjustable fuel pressure regulator, Drilled & slotted rotors/ceramics, GXP sway bars and STB, Upgraded and rebuilt transmission, Pioneer Bluetooth stereo with sub and 800 W amps, PB 13.5 quarter, (April 2014 car of the month)
PostPosted: Wed May 21, 2008 5:19 pm
Site Owner/Webmaster
'01 Sierra C3
Need to set it in your user control panel. It is a feature. I have to go look when I get a chance to see if I can set a default preference on that.
Owner / Admin
1995 SSEi / 2002 SSEi / 2001 Sierra C3 DENALI
PostPosted: Wed May 21, 2008 8:48 pm
I have searched everything in the User control panel and cannot find a toggle. [-X
PostPosted: Wed May 21, 2008 8:52 pm
You have to subscribe to get e-mails, not in control panel but at the top of each post.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:
Every time you pat my head, you pat a piece of my valve retainers.
PostPosted: Fri May 23, 2008 3:24 pm
Found it in the Control Panel. Thanks. :)
There are no new unread posts for this topic. Political threads...
TenGHz
Fri Nov 07, 2008 6:58 am
TenGHz View the latest post
cron
