It is currently Fri Mar 05, 2021 7:16 pm
Post new topic Reply to topic  [ 5 posts ]
 Post subject: 02 Buick Regal
PostPosted: Wed Dec 12, 2018 7:15 pm
Year and Trim: 2003 Bonneville SSEI
anyone have a link on how to change out the drivers side mirror glass only?
 Post subject: Re: 02 Buick Regal
PostPosted: Wed Dec 12, 2018 11:46 pm
Year and Trim: 2004 GXP, 2008 STS, 2008 DTS
The process is similar on many (but not all GM vehicles). For the regal, it should be the same as the Bonneville and Cadillac STS. Read through this post and I've documented important details about removing and reinstalling the glass. Geometry and alignment of parts on reassembly is critical so read carefully.
https://www.cadillacforums.com/forums/c ... embly.html
Wiring Harnesses, Custom Fuse Box & Tire and Loading Information Decals, Additional Acoustic Insulation
PostPosted: Wed May 01, 2019 6:17 pm
Thank you
PostPosted: Wed May 01, 2019 6:25 pm
Now another problem with the wife's car. It quit on us 2 miles from home this morning, the engine quit and I coasted to a stop, called the tow truck and is sitting in my garage now. As far as I know the only electrical item that has ever been changed out was the MAS. I was hoping it was the ICM but I swapped it out with the ssei and still will not start. I did that because the wife said a month ago the car quit on her a few times in town but started up and she went on here way and didn't happen since. I hear the fuel pump start and stop when the ignition is turned on, the fuel pressure at the rail sprays out good when I pushed the schrader valve in so, I have the crank sensor, maf and, the throttle position sensor and, possibly the cam position sensor if, that car has one, not sure. Where would you guys start or should I just replace all those sensors being the car is an 02 and has 150K on it. Thanks ahead of time
PostPosted: Wed May 01, 2019 10:50 pm
Well I checked the Throttle Position Sensor which seems to be good other than only 4 volts at wide open throttle. Most youtuber's showed over 4.5 volts but, I'm leaning towards the crank or cam sensor being the way it tries to start like its out of timing or having a crossed ignition wire which it does not
There are no new unread posts for this topic. 2002 Buick Regal
deano55
Sat Mar 03, 2012 6:12 pm
deano55 View the latest post
There are no new unread posts for this topic. 93 Buick Regal 3.8 has Spark & Fuel no Start
95naSTA
Thu Sep 11, 2008 10:10 pm
Mechanical Mike View the latest post
There are no new unread posts for this topic. 1991 Buick Regal Rear spark plugs
Merrillspontiac
Tue Nov 02, 2010 6:49 pm
human View the latest post
There are no new unread posts for this topic. 02 regal console
deano55
Fri Dec 16, 2016 9:22 pm
There are no new unread posts for this topic. 99' Regal GS Headlights Don't Work
Slayer636
Tue Apr 26, 2011 7:14 am
lukee1982 View the latest post
Users browsing this forum: No registered users and 2 guests
