EGR Issue!
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
philipk65
Year and Trim: 94 Olds 88 Royale 3800 series II, OBD I 120,000 K
EGR Issue!
Post by philipk65 »
Hi, I have a '95 Olds 88 with a 3800 series II engine, OBD I 120,000 miles on it.
My problem is that the dealer and auto shops, say I have a EGR code and keep replacing the EGR.(3 times now!) I still get the check engine light on and now the car has developed a miss/hesitation .
Does anyone have any other suggestions on what the problem could be?
Thanks! Kevin
1fatcat
Year and Trim: before cars
Re: EGR Issue!
Post by 1fatcat »
How are the plugs and wires?
philipk65
Re: EGR Issue!
Post by philipk65 »
The plugs and wires are new.
J Wikoff
Re: EGR Issue!
Post by J Wikoff »
Can you get the specific code numbers? Many autopart stores will scan your car. Tell them it's a GM OBD 1/2 car. It'll require a special scanner/cable combo.
